AndyRixon
- Joined
- Apr 7, 2023
- Messages
- 18
- Reaction score
- 16
- Points
- 3
- Age
- 33
- Location
- Scotland, UK
- Website
- www.andyrixon.net
Heyyy,
I have recently brought a 2006 Audi A4 2.0l S Line Avant with over 217k miles racked up. With this milage in mind the car came with a few gremlins, most of which I have managed to fix, but there is still one thing that has beaten me and I call on you guys in the hope I can get some answers, I have read a few of the other threads on here relating to similar issues and have applied some of the suggestions however none of them has worked for me. I hope I am posting this in the right place, if not please let me know.
The drivers door window seems to have spouts when it works, but mainly doesn't work, by which I mean doesn't go up and down, here is what I have tried to fault find my issue.
I have VCDS and the only fault that comes up is the following;
01331 - Door Control Module; Drivers Side (J386): Supply Voltage Too Low
So I am at a lose of what else I can check, I could just be having one of my brain farts and the problem is right in front of me, so I am hoping that "a second pair of eyes" from this forum could help
(P.S: I thought all these types of forums had died a long while ago, pleasantly surprised when I stumbled across this place rather than having to look at a Facebook page and potentially get the jokes ripped out of me)
- I have changed the switch (behaves exactly the same as the old switch, operates all windows apart from the drivers door window)
- Replaced the window regulator (Turned out both regulators work)
- Switched the window motors between the two regulators (Both motors seem to work fine)
- Checked for broken cables between the switch connector and the connector that goes into the window regulator (All of which seemed fine and working, using a multimeter for continuity)
- Checked every single fuse (While fault finding another issue) and replaced any and all that appeared broken
