Just been fitting my front/back Thinkware F770 2CH dashcams and I'm stuck at the final hurdle. The rear feed is fed all the way to the back of the headlining. I need to get it through the rubber gaiters that feed the boot wiring, but need to get the trim off inside the top of the boot. Got one clip removed but everything else felt rock solid and the moulding looked to extend to just by the back of the rear door opening. I even had a go at the mid boot trim after removing the torn screw, hot that half unclipped and bottled it - felt rock solid at the lower edges.
Looking to feed the cable through the rubber gaiters (probably passenger side one, it feels less full) into the tailgate. Tailgate trim removal looks easy - 2 torx screws in the hazard triangle holding recess then lever off the trim all around the perimeter to get the lower bit off, then unscrew the 2 screws holding the bottom arms of the upper trim and again lever off the clips.
If anyone has any diagrams for upper/mid boot inside trim, that'd be great.
Front dashcam all neatly hardwired and operational, with parking monitoring.
