Looking for some help please on my 2008 Audi A3 8P 2.0tdi
They key fob would not open the car nor would the key in the door. After much patience I managed to wedge the door open and install the key into the ignition, turn the ignition on, turn it back off and retrieve the key. The key fob then worked and allowed me access to the car, I tried the key in the door too and for some reason this also worked but not at the time when I was locked out. I don't want to lock the car again until I found out what caused the problem, please see an Auto Scan from VCDS below.
Saturday,06,May,2023,17:38:54:04602
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 23.3.1.0 HEX-V2 CB: 0.4631.4
Data version: 20230421 DS346.2
www.Ross-Tech.com
VIN: WAUZZZ8P19A013802 License Plate: XXXXX
Mileage: 242030km-150390mi Repair Order: 06052023
Chassis Type: 8P-AU35 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WAUZZZ8P19A013802 Mileage: 242030km-150390miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 BQ HW: 03L 906 022 BQ
Component: R4 2,0L EDC 0000SG 3066
Revision: 13H01--- Serial number: AUX7Z0H5FNR0PX
Coding: 0000072
Shop #: WSC 84736 041 600361
VCID: 75B7E10A59C029022CD-8020
VINID: 9D196AAAA22004944004320008B901CB84
1 Fault Found:
000136 - Fuel Rail/System Pressure
P0088 - 000 - Too High - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 241150 km
Time Indication: 0
Date: 2023.04.26
Time: 11:21:31
Freeze Frame:
RPM: 1587 /min
Inj. Quantity: 8.2 mg/str
(no units): 5.0
Pressure: 488.0 bar
Pressure: 824.0 bar
Temperature: 13.5°C
Tank Cont.: 16.2 l
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0104
Revision: 00H35001
Coding: 13424012092300FDC81302E4901B00823800
Shop #: WSC 06314 000 00000
VCID: 74B1DC0E5EBA300A1B3-8020
No fault code found.
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BH HW: 8P0 820 043 BH
Component: KlimavollautomatH09 0100
Revision: 000838 Serial number: 8P0820043BH
Shop #: WSC 00000 000 00000
VCID: 73B3DF1257B43732029-8026
1 Fault Found:
01232 - A/C Compressor Regulator Valve (N280)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 199
Mileage: 241553 km
Time Indication: 0
Date: 2023.04.30
Time: 18:00:30
Freeze Frame:
Load: 50.0 %
Current: 0.000 A
Address 09: Cent. Elect. Labels:. 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000008651075
Coding: 11A82F81B0141380EF00001C0000000000084E0564010403002800000000
Shop #: WSC 06314 000 08192
VCID: 48C958FE7EB2E4EA87B-801C
Subsystem 1 - Part No: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00056595
Shop #: WSC 06314
Address 15: Airbags (J234) Labels:* 8P0-959-655-10.clb
Part No SW: 8P0 959 655 J HW: 8P0 959 655 J
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003000000000 Dataset Number: 8P0909602H 0012
Coding: 303142383038303030374A55305238503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4_AU35.rod
VCID: 49CF5DFA69381DE2985-801C
Crash sensor for side airbag: driver side:
Serial number: 3572DRB400007748C29Z
Front Passenger's Side Airbag Crash Sensor:
Serial number: 3582DRB4000077449B3W
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 35128RB400003DBEFAA8
Passenger side rear thorax airbag crash sensor:
Serial number: 35228RB400003CCF117R
Crash sensor for front airbag: driver side:
Serial number: 35547RB400003D5F2B0T
Crash sensor for front airbag: front passenger side:
Serial number: 35647RB400003D5F1CD0
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0002012
VCID: 41DF45DA5D88D5A2405-8014
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0030
1 Fault Found:
00883 - Ignition Switch (D) Terminal S
012 - Electrical Fault in Circuit - Intermittent
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 C HW: 8P0 920 982 C
Component: KOMBIINSTR. VDO H15 0820
Revision: D0H15004 Serial number: 2245H004002157
Coding: 0004428
Shop #: WSC 12345 123 12345
VCID: 392F2D3A35588D62085-806C
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K0861109E2
Coding: E9807F060002022103
VCID: 3537210A19406902ECD-8060
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H15004 Serial number: AUX7Z0H5FNR0PX
Shop #: WSC 00759 210 91871
1 Fault Found:
16346 - Control Module - ROM Error
014 - Defective
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
Component: Tuer-SG H03 0060
Coding: 0000692
VCID: 43D34FD24794C7B2529-8016
3 Faults Found:
00109 - Left Mirror Turn Signal Lamp (L131)
01299 - Diagnostic Interface for Data Bus (J533)
004 - No Signal/Communication - Intermittent
00466 - Control Module for Steering Column Electronics (J527)
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.079 H08 1901
VCID: 363526060446621AE57-8062
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 J
Component: KSG H11 0080
Coding: 1980200002186D0985054C9FC637
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
1 Fault Found:
00849 - S-contact at Ignition/Starter Switch (D)
008 - Implausible Signal
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Coding: 0000692
VCID: 44D14CCE429AC08A6B3-8010
2 Faults Found:
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 186 P HW: 8P0 035 186 P
Component: R Concert2+ H02 0270
Revision: 00H02000 Serial number: AUZ1Z3H8934359
Coding: 0310201
VCID: 3FDB43222B7CA352361-806A
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
Component: Tuer-SG H04 0040
Coding: 0000144
Shop #: WSC 06314 000 1012544
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
Coding: 0000144
VCID: 42DD4AD6588ECEBA59F-8016
End----(Elapsed Time: 01:12, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
Any help would be greatly appreciated, cheers.
www.Ross-Tech.com
Coding: 0000072
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 241150 km
Time Indication: 0
Date: 2023.04.26
Time: 11:21:31
Freeze Frame:
RPM: 1587 /min
(no units): 5.0
Pressure: 488.0 bar
Pressure: 824.0 bar
Temperature: 13.5°C
Tank Cont.: 16.2 l
Revision: 00H35001
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 199
Mileage: 241553 km
Time Indication: 0
Date: 2023.04.30
Time: 18:00:30
Freeze Frame:
Load: 50.0 %
Current: 0.000 A
Coding: 00056595
Shop #: WSC 06314
Coding: 0002012
1 Fault Found:
Coding: 0004428
1 Fault Found:
014 - Defective
Coding: 0000692
3 Faults Found:
1 Fault Found:
Coding: 0000692
2 Faults Found:
Coding: 0310201
Coding: 0000144
Coding: 0000144
