As I now use Apple Music as its better quality than Spotify and it has lossless. But I read you need a dac for lossless. Am I just wasting data using lossless with the car B&O? Or does it benefit from lossless?
Over the years, I have come to the conclusion that it comes down to personal experience. If 320kps sounds good to you, then you can happily use the smaller file sizes. If not, then use the better quality files. The same rule applies to buying hi-fi: if you can tell the difference between a more expensive component and a less expensive one, buy the more expensive one; otherwise spend your money on something else.I would say even with the road noise and other contributing factors there is a good difference between 320kps and 1411kbps. It all depends on how good the audio system is. I’ve never been massively impressed with any stock system, including Audi’s own, Bose, B&O etc.
100%. It’s all down to the individual, we all hear things differently. I’m a massive fuss pot when it comes to audio, I can’t stand heavily compressed music unless it’s internet radio.Over the years, I have come to the conclusion that it comes down to personal experience. If 320kps sounds good to you, then you can happily use the smaller file sizes. If not, then use the better quality files. The same rule applies to buying hi-fi: if you can tell the difference between a more expensive component and a less expensive one, buy the more expensive one; otherwise spend your money on something else.
That does sound a little odd, but I wouldn’t put it passed Audi to have the settings back to front.I also find some days the stereo isn’t as loud and I’ve got it turned up more. Maybe that’s the stream changing or my ears? Lol. I still don’t understand the “subwoofer “ and “bass” settings as subwoofer doesn’t do anything if bass is off or vice versa. Usually subwoofer settings would just be for the sub but it’s different in the Audi.
“bass” seems to make the sub louder and “subwoofer” seems to make door speakers louder. I’m confused? But then I also turned subwoofer right down and bass on max but then I had no bass at all? How does it work?
Or maybe subwoofer just adjusts the sub level to match the bass setting? So if bass is on zero , there will be no sub at all either. Or if bass is on max it maxed the subThat does sound a little odd, but I wouldn’t put it passed Audi to have the settings back to front.
Our hearing does get progressively worse the older we get which doesn’t help either. You could always do some subtle mods to the audio system, speak to your local reputable car audio centre.
