Audi A3 1.8 TFSI - dreaded P2563 error code (wastegate/actuator)
swgdesign
Maidstone
I had new rear discs and calipers fitted yesterday as they were sticking badly, but that highlighted another issue; the dreaded P2563 error code related to turbo wastegate actuator! :(
Weirdly, I have had intermittent issues with Stop/Start being available over the last year, and someone in another forum said replacing the actuator solved both issues, so I am hoping this is the same for me.
What have people tried to fix this error code, which equated to not having to buy a new turbo?
VCDS scan below (ignore abs, the sensor snapped off and the repair has failed)
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F
VIN: WAUZZZ8V0FA098383 Mileage: 85680km-53239miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-CJSA) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 264 E HW: 06K 907 425 A
Component: 1.8l R4 TFSI H09 0002
Revision: --H09--- CVN: 15DF10B1
Coding: 0A2500322424010B2000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM18TFS0218V0906264E 001003
ROD: EV_ECM18TFS021_AU37.rod
VCID: 3E253EA870FEEFFA1DF-806A
VINID: 9D196AAAA2260164402480C80C5586B448
1 Fault Found:
14846 - Turbocharger Boost Control Position Sensor Circuit
P2563 00 [10101111] - Implausible Signal
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Mileage: 85574 km
Date: 2024.04.10
Time: 10:26:39
Engine RPM: 2181.75 /min
Normed load value: 30.2 %
Vehicle speed: 50 km/h
Coolant temperature: 104 °C
Intake air temperature: 18 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 14.042 V
Unlearning counter according OBD: 40
Status of charge air pressure control valve basic setting-LV_BPA_AD_REQ[0]: 00000001
Charge air pressure control valve uncond voltage sensor-VP_BPA[0]: 4.5020 V
Charge air pressure control valve position: target value-POSN_SP_BPA[0]: -0.00 %
Charge air pressure control valve position: actual value-POSN_BPA[0]: -0.391 %
Charge air pressure control valve activation pulse duty factor-PWM_BPA[0]: -23.026 %
Charge air pressure control valve voltage: position closed-VP_BPA_AD_BOL[0]: 4.4824 V
STATE_BPA[0]: AD
Readiness: 0000 0001
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 047 F HW: 0AM 927 769 K
Component: GSG DQ200-MQB H43 5201
Revision: 00043014 Serial number: CU501411195185 CVN: 0000A4AD
Coding: 0014
Shop #: WSC 17734 418 534600
ASAM Dataset: EV_TCMDQ200021 001001
ROD: EV_TCMDQ200021_VW26.rod
No fault code found.
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 3Q0 907 379 F HW: 3Q0 907 379 F
Component: ESC H42 0609
Revision: 00000000 Serial number: 63234000004813
Coding: 10F18AA234292A74017A060841C62908512C5480608294F4024150788208
ASAM Dataset: EV_Brake1UDSContiMK100IPB 034027
ROD: EV_Brake1UDSContiMK100IPB_034.rod
VCID: 3D2739A47DF8F4E2045-8068
1 Faults Found:
0213 - Vacuum sensor
C10A3 29 [00001000] - Signal Implausible
[Single Vacuum Pressure Sensor sends no valid data]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 254
Mileage: 85574 km
Date: 2024.04.10
Time: 10:25:32
Address 08: Auto HVAC (E87) Labels:| 8V0-820-043.clb
Part No SW: 8V0 820 043 C HW: 8V0 820 043 C
Component: AC Automat H13 0060
Revision: 20027000 Serial number: 00000000501167
Coding: 00100004000000011000000000001100
ASAM Dataset: EV_AirCondiFrontVaAU37X 008020
ROD: EV_AirCondiFrontVaAU37X_008.rod
VCID: 323D1A98B4A63B9AE97-8066
Humidity sensor: exterior:
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: 5468CC57000000000001
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AJ
Component: BCM MQBAB H H18 0137
Serial number: 01011432201542 Dataset Number: 8V0909514K 0081
Coding: 07041A42C20122FD03044004B31C07A80004000000000000000000000000
ASAM Dataset: EV_BCMCONTI 013000
ROD: EV_BCMBOSCH_013.rod
VCID: 005980504A8A590A2F3-8054
Wiper motor control module:
Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 141109 041 0580
Serial number: 141113234714
Coding: 0A47F7
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 23489084
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 AE HW: 8V0 941 531 AE
Component: E1 - LDS MQB H05 0032
Serial number: 03 09 2014 00000471
Anti-theft alarm system sensor:
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY142741EK8
Alarm horn:
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000061007602
3 Faults Found:
197644 - Control Circuit for Fuel Tank Flap
B1263 01 [00001001] - Electrical Failure
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 151
Mileage: 84929 km
Date: 2024.03.14
Time: 14:32:34
Terminal 15 status: OFF
Terminal 50 status: OFF
CAN-Bus_aktiv: On
Status Bremslichtschalter (HW): OFF
Status Bremslichtschalter (CAN): OFF
OFF: Not operated
Position lamps: Not operated
Automatic high beam assist: operated
Low beam: Not operated
Parking light left: Not operated
Parking light right: Not operated
last_wakeup: no cause for fault protection
Voltage: 12.4 V
Outside temperature: 17.0 °C
197904 - Central Locking
B140A 4B [00001000] - Over Temperature
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 219
Mileage: 85140 km
Date: 2024.03.19
Time: 17:12:27
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 12.4 V
Outside temperature: 13.5 °C
204290 - Remote key 1
B1479 18 [00001000] - Current Too Low
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 0
Mileage: 84929 km
Date: 2024.03.14
Time: 14:32:33
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 12.5 V
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5Q0 919 298 G HW: 5Q0 919 298
Component: PARKHILFE PLA H12 0051
Revision: -------- Serial number: 39431427400521 Dataset Number: 8V0909526D 0040
Coding: 0110060051
ASAM Dataset: EV_EPHVA2CAU3700000 003019
ROD: EV_EPHVA2CAU3700000_003_AU37.rod
VCID: 43D34F5C1B1C8212721-8016
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
Component: AirbagVW20 011 0361
Serial number: 003M2R09EFFL Dataset Number: 8V0909602C 0009
Coding: 98CCC0000C0000005C5400CA00C800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 4BC3677C334C4A528A1-801E
Crash sensor for side airbag: driver side:
Subsystem 1 - Part No SW: ----------- HW: 480 001 411 14
Component: SideSensor_Df 001 0887
Serial number: 357670000009DA50811W
Coding: 2D2D2D
Front Passenger's Side Airbag Crash Sensor:
Subsystem 2 - Part No SW: ----------- HW: 480 001 411 14
Component: SideSensor_Pf 001 0887
Serial number: 358670000005DA50811T
Coding: 2D2D2D
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 3 - Part No SW: ----------- HW: 480 401 311 14
Component: SideSensor_Dr 001 6149
Serial number: 3516502C5188FC12823D
Coding: 2D2D2D
Passenger side rear thorax airbag crash sensor:
Subsystem 4 - Part No SW: ----------- HW: 480 401 311 14
Component: SideSensor_Pr 001 6149
Serial number: 3526502C7188FC12F36R
Coding: 2D2D2D
Crash sensor for front airbag: driver side:
Subsystem 5 - Part No SW: ----------- HW: 480 402 810 14
Component: FrontSensor_D 001 6149
Serial number: 3556502AF1860BC4439N
Coding: 2D2D2D
Driver's side crash data pedestrian protection:
Subsystem 6 - Part No SW: ----------- HW: 480 402 710 14
Component: PedP_Sensor_D 001 6149
Serial number: 2286502C31811BA49122
Coding: 2D2D2D
Passenger's side crash data pedestrian protection:
Subsystem 7 - Part No SW: ----------- HW: 480 402 710 14
Component: PedP_Sensor_P 001 6149
Serial number: 2296502AF1811BA1F24J
Coding: 2D2D2D
Center pedestrian protection crash sensor:
Subsystem 8 - Part No SW: ----------- HW: 480 402 810 14
Component: PedP_Sensor_C 001 6149
Serial number: 2306502C71697524F0EE
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
Part No SW: 8V0 953 521 BP HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 25111404220213
Coding: A418
ASAM Dataset: EV_SMLSKLOMQB 017001
ROD: EV_SMLSKLOMQB_017.rod
VCID: 094F9D7479B0184278D-805C
1 Fault Found:
617752 - Selector Lever Park Position Lock Switch
B1162 29 [00011000] - Signal Implausible
Intermittent - Confirmed - Not Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 244
Mileage: 85173 km
Date: 2024.03.22
Time: 19:00:32
Operating time: 155590 min
Terminal 30 power supply: 14.7 V
Vehicle speed: 21 km/h
Voltage at switch: 4.98 V
Terminal 15 status: active
System status: 30
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 8V0 920 971 C HW: 8V0 920 971 C
Component: KOMBI H02 4291
Coding: 27A501082B9026000100E8001000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009040
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 F
Component: GW MQB High 128 1204
Revision: -------- Serial number: 0002722931 Dataset Number: 8V0909515F 0060
Coding: 030100043F085A005B0002481C0B00000001010000000000000000000000
GVL: 01543C0000000000400C10000000C80000000000000000000000000000000000
ASAM Dataset: EV_GatewLear 011020
ROD: EV_GatewLear_011.rod
VCID: 72BDDA9874267B9A297-8026
Generator:
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 8U0 951 528 C HW: 8U0 951 528 C
Component: E221 - MFL H02 0014
Serial number: 14 11 2014 B0046013
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 H HW: 5Q0 915 181 H
Component: J367-BDMConti H02 1011
Serial number: 74185703001411141749
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 393 D HW: 5Q0 959 393 B
Component: TSG FS 020 0028
Serial number: 10111401101484 Dataset Number: 8V0909872F 0032
Coding: 00100E204001040100001002
ASAM Dataset: EV_DCUDriveSideEWMINKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 40D940500A0A990A6F3-8014
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 125 1061
Dataset Number: 8V0909852K 0021
Coding: 8303
ASAM Dataset: EV_SteerAssisMQB 012140
ROD: EV_SteerAssisMQB_012_VW37.rod
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 392 D HW: 5Q0 959 392 B
Component: TSG BFS 020 0028
Serial number: 04111401100401 Dataset Number: 8V0909873F 0032
Coding: 001006204001040100001002
ASAM Dataset: EV_DCUPasseSideEWMINKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 3FDB43AC77F4E6F2169-806A
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Revision: -------- Serial number: -------------- Dataset Number: 8V0909865L 0038
Coding: 019E000001000000
ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
ROD: EV_HeadlRegulVWLWRMQB.rod
VCID: 75B7E18405486CA20C5-8020
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-STD1.clb
Part No SW: 8V0 035 874 B HW: 8V0 035 874 B
Component: MU-S-ND-ER 041 0420
Serial number: A7F02111143355 Dataset Number: 8V1909545D 0040
Coding: 01730001FF00000011111101000A00002F0004060100010006
ASAM Dataset: EV_MUStd4CPASE 002018
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 3B2337BC63ECFAD23A1-806E
Data carrier:
Subsystem 1 - Part No SW: 8V0 919 866 C HW: -----------
Component: ECE 2015 --- 0045
Serial number: --------------------
Multimedia System 1:
Subsystem 2 - Part No SW: 8V0 919 603 C HW: 8V0 919 603 C
Component: DU Std H49 0013
Serial number: AUZ8Z9EY307KUS
Multimedia system control head:
Subsystem 3 - Part No SW: 8V0 919 614 P HW: 8V0 919 614 P
Component: ControlUnit_B H41 0054
Serial number: C1000004101400030102
End----------(Elapsed Time: 01:19, VBatt start/end: 14.6V/14.7V)-----------
read this try everything that doesn't mean replacing the turbo, including cleaning the VNT mechanism of the turbo first. if that doesn't help it's either replaceing the core of the turbo, get a refurbished turbo or a used turbo that you clean first before putting it on the car. you also want to make sure that all the vacuum lines are airtight (replace the lot with silicone vacuum lines (you'll need 3mm ID silicone vacuumlines)
Thanks for the tips.
I've bought some Wynns Turbo cleaner, so that should help clear any build up. I'm also going to check if the actuator is loose or stiff due to external factors/build-up, and then try to free it if it is using wire brushes and wd-40.
I'll also check all pipework tomorrow - just waiting on a endoscope to be delivered as there's no way I can see all the connections without one.
Reactions: northpole
Does anyone have the actuator and/or turbo part number for an Audi A3 8V 1.8 TFSI ?!
I’ve found a recon turbo but need to make sure of part number.
In case anyone has this issue and need a replacement turbo, the part on my 2015 1.8 TFSI S-Line is 06K 145 701 T
Reactions: ahtcap
