Temperature Gauge Fault
Russ S3
Hi This just started yesterday. The temperature gauge needle starts to go down but if you stop the car turn the ignition off the turn the key again the needle goes straight back upto the normal point (90). it never goes up just drops then goes back up. the heaters keep blowing out hot air so i'm wondering if its a sensor or something that i can replace ? the car seems to be running ok. can anyone shed any light? that would be great. Ps i'm not a mechanic so laymans terms would be great cheers.
For the cost of them, I'd stick a new sender in it. Fitted in the water pipe/outlet from the head above the gear linkages. A 10 minute job. Get a new O ring as well.
Gavin
Courtesy of madvw:
1 Fault Found:
17704 - Error in Mapped Cooling System (usually temp Sensor or Thermostat)
P1296 - 35-10 - - - Intermittent
anyway.. back from audi with a new coolant sensor and o-ring, parts for a BAM are:
A059 919 501A - C3D1 Temperature Sensor
AN 903 168 02 - C3D1 O-Ring
£24 +vat.
and also the excellent how-to for a BAM engine:
http://www.wak-tt.com/tempsensor/tempsensor.htm
Courtesy of Prawn & S3 Dave
For the thermostat: http://www.audi-sport.net/vb/showthr...ght=thermostat and for guides: http://forums.audiworld.com/tt/msgs/1304805.phtml
Thermostat from VagParts
050121113C for the Thermostat S3 £17.00+ VAT
038121119B for the Thermostat O-Ring 57p+VAT
10
952
954
950
957
