im trying to replace my dv with a foorge 007p but can someone please tell me the easy way to get those ******* clips off that hold the standard bosh valve on there!!! cheers
I used pliers on mine... just bend the little tip straight, that sticks out and holds the whole lot together. Careful not to cut the pipework if you get frustrated.
Careful use of a dremmel cutting disc or if you have some large side cutters cut through the crimp on the clip and when its split the hose clip can be pulled apart.
