1.9 tdi offset
clough103
coming up to needig my tyres replaced, so thinking of replacing the old dull alloys with something nicer.
have seen loads of other 5 spoke wheels from the newer A4 and the RS6 etc.
What is my offset on an a4 1,9TDI advant and are these newer wheels likely to fit ok
cheers
Standard B5 fitting is ET45. Just about the same as everything else on here ET45. You can vary your fitting to your ride, i.e. drop, width (with spacers etc). Most Audi A5 (b5) and A6's 97 onwards will fit. Rubber may make a difference.
ive seen some rs4 wheels that look nice. they have 225 tyres on. do you think i would have any problem with these?
cheers
if they are REAL RS4 wheels, then they are ET20 and 8.5" wide and wont fit.
If they are replicas they will most likely fit just fine, as they tend to be narrower and the correct offset
919
13
