k03s help
zeeeebo
Lifes one big laugh
worthing
ok yesterday i brought a K03s ( silenced) and basically i had 2 questions hopefully someone can help me with as i have searched on google andhere and cant find a straight cut answer!
1. is it normal to have very mild cracks down the hole with 3 screw holes? it doesn show from the outside but i had a look down it with a torch and you can see a few cracks
2 going to have a go at swapping this for my old ko3 ( non silenced) turbo and want it to be a straight swap but am understanding i need a few bits! i have all the gaskets but do i need any differnt screws etc? also because its a silenced one i am on the understanding i need a new hose in? does anyone have a link to one that will fit? apart from that will all the hoses i already have fit?
nathan
I am not sure on the specifics of the swap, but small cracks are pretty much the norm tbh, as long as they are not through to the outside or around the WG flapper its good to go
Sorry bud, didn't see this post.
Cracks should be OK as long as they aren't colossal. How old is the turbo? Check for shaft play as normal.
Installation not the hard to do to be honest. There is a good guide on the web here: http://uk-mkivs.net/forums/t/265756.aspx. See I even went and found it.... awwww. :)
Anyway, this will tell you what you need bore you start. And also how to. You WILL need 3 turbo - exhaust manifold studs, even though the guide says they're emergency only.
K03 TIP doesn't fit well onto a K03S, best swapping out for a forge one... or an eBay one http://cgi.ebay.co.uk/AUDI-TT-TURBO...arts_Vehicles_CarParts_SM?hash=item1e589ca571 which is decidedly cheaper than Forge's but exactly the same. Thats what I did anyway....
The pipe with the silencer coming out of the K03s is slightly smaller than the K03. I clamped the original hose from the K03 onto the K03S with a cut bit of another hose around the inside to bulk it out for a better fit if that makes sense?
Other than that, everything is the same.... Execpt the spool up sound, which will make you jizz I expect.
cheers mate ill give it a shot and let you know how it goes!!
just changed my k03s, after i broke my other k03s, i found it easyer to take manifold off instead of dropping downpipe, took me about 4 hours in totaly from start to finish, so much easy with the manifold out of the way as pipes and everything is so much easyer to get to, also a good idea to change oil
Thats the way I did mine to be fair....
13K
49
10K
843
syp
704
