got my new car to a point it should pass mot except for one problem abs seems to kick in too early
from medium braking at low speed abs kicks in just before it comes to a complete stop
all disks and pads are good, changed brake fluid for fresh dot 4, cleaned abs rings and sensors whilst it was all stripped
no fault codes logged on vagcom, all sensors are showing similiar speeds (meas. blocks channel 1)
tried removing fuse and it takes more effort (i think) to lock them up than for abs to kick in
anything else i can check with vagcom or am i missing something obvious? whilst typing ive just remembered ive not checked tyre pressures so will try that
also anyone who uses eezibleed take note of bit where it tells you to pressure test system before starting, i didnt and reservoir burst spraying new fluid everywhere, didnt notice hairline cracks at rear where sunlight gets to it, luckily i had a spare
