You and your phone spin i rang you about 8 .
i got the wheels dirt cheap .
Are a set of 19"bbs ch et 50 with 225 35 19 tyres the perfect fit for my s3 with a srt of h&r springs .
And i will not get any rubbing ?
I would imagine you would need 215 tyres from what I have read.
It all depends on tyre make apparently also
With ET50 and 235 you will get no rubbing as that is what setup Boydie is running...
i had the same issue as v6pete.
i am running 235/35/19 yoko S drives and i had lots of rubbing on the back wheels.
had to remove a fender screw on each side of the rear to sort the problem.
ideally you would want to run 225/35/19's.
thats with a set of 19 inch bbs ch 50 offset and 8j.
I concour! 8.5x19 et50 235/35/19 lowered on H&R springs will not rub!
Tyres that I have had are:
Federal
Kumho
Bridgestone Potenza's
Good Year Eagle F1's
If your car rubs on 235's then you are gay, plain and simple
just listed in classifieds.. set of bbs ch 19 exc cond £1100... good price!
Dohhh ! Got it now thanks,
