Hello, recently had to replace my abs pump which now needs coding to my car. Can the code be determined from the codes in the service booklet or is a scan required?
Simples if you have done autoscan b4 you only need to go into your tosstech folder find it , open it and note coding then just apply that to your new pump and then do what else you need to do .
