Only thing to watch on the 3dr is when drilling out the rivets, I will make a point of trying to remove the whole piece as I suspect going round corners you may get a small tiny metal tinging noise from the bits drilled throigh that have dropped into the pillar cavity, I need to take the interior area trim of to check behind, hopefully should be possible to grab at same time.
