To give you some idea of the UK costs. According to the parts catalogue ETKA, the flat botton steering wheels costs £372, the same but multi-function is £463 and if you need a new airbag unit to match the wheel this is £648. Not a cheap option!!!
Dave, the prices on my ETKA dont seem to make sense half the time... can you find out the price for a RS3 or RS6 wheel? i want the thicker one but would need an airbag... had a look on ebay but those seem way to much for this wheel...
i think the RS3 and RS6 wheels are the same as the TT-RSGet the TTRS one they are alot thicker than the other wheel
It depends on what car you are fitting it to. If the car doesn't already have a MFSW then you will probably need to replace the steering ecu for a highline one. You will also require coding if there's no MFSW as standard.
The physical job of swapping out the wheel isn't that difficult if you've got the right tool for the bolt in the middle of the wheel. I can't remember what tool it is that's required.
well you can take my sline MFSW and re trim it!
