What have you done to your 8V today?
Bit of routine maintenance - checking pressures and fluids.
Decided to change the air filter and clean out a few dried leaves and a dandelion seed from the air box. Was surprised how clean the filter was but as I was there, changed it anyway.
Changed comfort indicators to 4 flashes which was fine but it somehow reset my door locking settings to unlock all doors and not to fold mirrors on lock. Strange they reset but easy to put them back how I wanted them.
Reactions: Bells
Paid to extend my warranty for another year. Just need to pay for the Breakdown cover through Audi and thats me spent up for another couple of months
Reactions: JohnM100
Added grey wheel bolt covers
The bolts was new when the wheels went on. But was starting to look a little worse for wear
so I had some new grey bolt covers
I believe they was from a seat many tears ago
just had to order the correct tweezer tool to remove them as I don't want to be damaging them or my wheels on removal
A pre-winter wash and polish, swapped out the carpet mats for rubber ones, and swapped the 19" summer wheels for some 17" ones with Nokian winter tyres. Do look a bit odd on the S3 but I already had them from my A4 and they were fully refurbished after last winter. All they needed was some spigot rings. They clear the calipers by about 10mm. Surprisingly the swap hasn't affected the ride over-much (I'm running them at 36psi front, 32psi rear) but it is significantly quieter on the tar-and-chip finish on the A41 locally.
nothing from day when i have it :) byt planning to make powerfolding mirrors dechrome and install rs3 grill :D
Got some custom made floor mats.
Reactions: Jcbmally, danboy66 and AGGRESSOR
Booked it in to get the last of the de chroming done on the window surrounds on Monday, can’t wait.
Put an rs3 exhaust on the normal 4 banger to better control the sound. It's very quiet with flaps closed and similar to a straight pipe when open!
The fabrication of the y pipe wasn't as hard as I thought it would be, but my welding needs some more practice
Sent from my Pixel 3 XL using Tapatalk
Reactions: Dubjam, Leevr, pburv and 2 others
Finally, I found and fitted a black grille badge suitable for an aftermarket RS3 style grille. The badges that fit the oem grille were a bit too small, but this one is exactly the same size as the chrome one that was fitted to the grille from the factory.
Black grille badge
Reactions: Fatbloke, Dubjam and Leevr
Stage 1 done by Performance Engineerings Cardiff
150bhp - 190bhp
365nm - 450nm
New VAG metal pedals
New RS3 Grill
Reactions: Sve and Pur8
MOT day and looking at the mileage since last year my New Years resolution is to go on some epic trips in 2021. Unfortunately not driven much this year due to lockdown and working from home etc. Had her since new and as you can see, low mileage for 6 years old........ still like a new car :)
7569601B 27BD 4033 9A30 3AF9571DCC16
Reactions: JohnM100 and Jcbmally
Just over 1k miles in a year...crazy!! Definitely need a few road trips next year.
Reactions: Jcbmally
Liking this. So you adapted it at the down pipe? do the tips line up with the S3 Diffuser ok?
Do you have a link for these mate?
Diamond car mats.
Claimed they were a UK company but they came from China.
Despite customs of 25.00 and the mats were about 100 with %25 off, they are good quality.
I would wait for boxing day for another 25% off. Took about 6 weeks delivery.
Reactions: ScottishA4B9
Installed a RS3 grill from GBT Autostyling on ebay.
Reactions: ScottishA4B9, dp_motley and pburv
Well, not me but got the black ambience panels on the doors PPF’d as they can be scratched just by looking at them.
Reactions: Jcbmally and pburv
Swapped the insides of my key into a shiny new one ! Now the key blade no longer pops out and pokes me ! Also looks so much better than the poverty spec key our cars got... I will do a full write up in the next couple of days.
IMG 5583
IMG 5612
IMG 5611
IMG 5613
IMG 5596
IMG 5602
Reactions: Leevr, pburv and JohnM100
Trying out some ideas on pin striping on the rear diffuser.
20210102 120328 copy 3024x1470
20210102 120332 copy 3024x1470
Reactions: Jcbmally, jrumball and pburv
Gave the car its first clean of the year
Anyone on insta add me up @dan66jones
Reactions: Phil-1 and josul
Lockdown & cold weather finally killed my already dying Moll EFB battery (week 24 2018 so just after bad batch batterygate).
Installed and coded a shiny new Varta AGM instead, as I suspect warranty would be denied due to low mileage/use.
Not much room under the bonnet - would probably remove the air box next time for better access.
Was trying to wire in a CTEK charger flylead at the same time: Negative attached to the chassis ground fine but anyone else noticed what appears to be a captive nut on the positive terminal clamp, so open to suggestions.
On the bright side, no need to use BEM codes any more.
Was trying to wire in a CTEK charger but anyone else noticed what appears to be a captive nut on the positive terminal clamp, so open to suggestions.
Just cut the ring terminal on your charger cable enough to slot over the battery fitting thread & then clamp it tight with the nut.
Reactions: JohnM100
This. Snip a section out of the ring in order to make a C shape.
Reactions: JohnM100 and 8YARWY
Bought myself the DTUK pedal box + . Always felt the throttle pedal has a delay/dead spot on first press. Hopefully this'll sharper it right up.
20210302 111644 copy 3024x1470
20210302 111705 copy 3024x1470
Reactions: JohnM100 and Madmo
You will absolutely love it especially on sport +
Sent from my SM-G950F using Tapatalk
Does it make that much difference on the S3?
I had one on my stage 1 BMW 125D and it made a world of difference when set to S+
Sent from my SM-G998B using Tapatalk
well it certainly does on mine but I also have a GFB DV+ valve fitted so that helps with the slight lag when changing up
Reactions: Andru8
