What have you done to your 8V today?
MTEC Black Edition Dimpled and Grooved with Mintex Pads
Have you driven much with the mintex pads? Mine squeaked for a good 500 miles until they were worn in
Installed a BMS turbo inlet pipe, 10 min job for much improved the throttle response at low revs, boost feels like it hits earlier as well. Very happy.
Reactions: dp_motley
Finally got round to sorting out my little accident with a curb!!
Reactions: Ormesome, rcnacura, SPIKE_ and 2 others
Only done around 10 miles tbh, haven’t heard them squeak. Did you fit the shims?
Not sure if the shims were fitted or not as I didn’t fit them, but after a couple of days for the the squeaking was very loud and it took some effort to wear them in... probably a month or two before they stopped squeaking when cold
Nice job - how did you achieve that?
Cheers, started with 400 grit wet and dry until deep scratches were removed then continued with 800, 1000, 1500, 2000 and finally 3000 followed by a good metal polish.
Reactions: Jassyo06, dp_motley and OCDaveS4
Took my turbo out to upgrade it in a few weeks.
Next few days hoping to do some more sound deadening and rehookup my e85 analyser.
Sent from my Pixel 3 XL using Tapatalk
What did you do to seal it? Clear lacquer?
I had a small bottle of lacquer from ebay with a brush but when applied it looked a mess so had to re-sand and polish, going to get a spray can to get a good finish.
Reactions: OCDaveS4
That’s interesting because I touched over some small chips on my DC alloys with lacquer to repent water penetration but after a few weeks it all went “milky”.......
Not a lot apart from watched it gather dust, couple of things i want to do but looking for best place and price to get them.
Gloss black badges for front and back as audi want £40 each and am not wanting to pay that. Some short plates in 4d gel. And some Audi puddle lights.
Freshmodsuk on Instagram! Can't fault the quality, good value too. Got rings and badges for my S3 and S5. They also do plates.
Sent from my HD1913 using Tapatalk
I don’t have instagram does he have a facebook page or an email address i can contact him on?
Managed a 4.38 second 0-60 mph launch control test. IE Stage 1 high torque with DSG tune (3200 rpm version).
Seems reasonable, albeit high for a Stage 1 tune. Maybe tires were too cold.
Dash Command iOS app using a OBD2 Wi-Fi dongle.
IMG 3861
Sorry if I’ve missed it, but is that an otherwise standard S3 saloon (judging by your profile pic)?
Cleaned my steering wheel. Was watching YouTube and a tip came up that a magic eraser/sponge with just water can clean/ de grease the wheel. As I'm getting a new wheel soon when were out of lockdown I thought I'd give it a go. I have to say. It worked a treat. Very light rubbing with a wet sponge for a few seconds and dry with a microfiber towel. Big difference. If you do and it messes up I hold no responsibility.
Before
20200331 093122 copy 1470x3024
After
20200331 093338 copy 1470x3024
Reactions: habitat
Wow that’s quite a difference and a nice matt finish
Reactions: Leevr
Made this video about upgrading subwoofer after upgrading the powerblock and moving fuel-it sensor out of engine bay.
Reactions: Baka and Lehn
In the midst of a full correction and ceramic coat.
And epoxy garage floor coming soon!
685CB388 D38B 44FC 8B0B 851A22870C67
Reactions: Nelka and SPIKE_
Waiting in the line to extend my A3 registration...
Not driven the car much with everything that’s going on at the moment but I did get round to fitting the extended leather on the centre console, grabbed a bargain full centre console on eBay for only £60 so thought it was worth the plunge.
There’s a few guides on here that I followed but it took me a good few hours and did have to go back and re-glue one side as it had lifted slightly but it’s now stuck down solid so I’m happy. Think it looks miles better than the previous plastic trim and it no longer squeaks!
Just need to source some leather door cards for a 3 door next, and maybe try wrapping the interior trim in carbon fibre also keep getting tempted by RS3 style grills!
Reactions: Jassyo06, Joxh, Naim and 1 other person
Extended leather is defo a must, looks much better mate!
If after a grill hit up fresh mods UK on Instagram, good quality and decent prices. Got mine from there!
Reactions: Bells
Cheers mate :icon thumright: Might have to take a look, think the S3 fitting is a bit more complicated and needs more ‘modification’ than the S5 from what I’ve seen which is my only concern. Mind you I’d be getting my local body shop to take on the job once we get back to normal anyway!
Reactions: Adam14
Bored so cleaned, polished and waxed - not looking too shabby for 4.5 years old (IMHO)
Reactions: Dunedin, Baka, rvtb101 and 2 others
Hi . I am thinking of this mod .the leather console sides . If you e bought a complete console can you not just exchange without remove and re fixing the knee pads ? Thanks
Sent from my SM-G950F using Tapatalk
I could potentially have done but it would have meant ripping out the whole of my centre console which would have been a lot more work I think.
Also the centre console I bought was from a 2016 RS3 (PFL) and with my car being a Facelift I wasn’t sure things like my wireless charging pad in the armrest would be a straight swap and didn’t want to run into any issues.
Single stage polish & a coat of Fusso Soft99
Reactions: N.J.H, Philip Davies, SPIKE_ and 2 others
Thought this would help because I followed the video and it was better then other videos encourage you to bend the hinges in and risking you to snap the hinges!
I was searching ages for a tutorial video and I think this covers everything.
