Darran
VCDS Version: Release 12.12.0
Data version: 20130910
Sunday,01,February,2015,14:36:43:62939
Chassis Type: 8H (8E - Audi A4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAUZZZ8H83K021003 Mileage: 166760km/103619miles
Address 01: Engine Labels: Redir Fail!
Part No SW: 8E0 909 518 AA HW: 8E0 909 018 A
Component: 1.8L R4/5VT 0004
Coding: 0011504
Shop #: WSC 00672 785 00200
VCID: 6FED35377D68D7667D9-5000
1 Fault Found:
17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28)
P1340 - 001 - Incor. Correlation
Readiness: 0110 1001
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 1729
Coding: 04475
Shop #: WSC 00672
VCID: E5C1D71F7F949D36875-5072
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
35-00 - -
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 J
Component: A4 Klimaautomat 1116
Coding: 00100
Shop #: WSC 00672
VCID: 285F1E2BC806C05EFC3-5000
2 Faults Found:
00710 - Defroster Flap Positioning Motor (V107)
41-00 - Blocked or No Voltage
01272 - Positioning Motor for Central Flap (V70)
41-10 - Blocked or No Voltage - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00001
Shop #: WSC 00672
VCID: 3467FA5B04CEB4BE40B-4A9C
4 Faults Found:
00978 - Lamp for Low Beam; Left (M29)
57-00 - Electric Circuit Failure
01519 - Bulb for Back-Up Lights; Right (M17)
01502 - Bulb for Rear Fog; Left (L46)
01800 - Light Switch (E1)
27-10 - Implausible Signal - Intermittent
Address 15: Airbags Labels: 8H0-959-655-84.lbl
Part No: 8H0 959 655 B
Component: Airbag 8.4EC 1015
Coding: 0011104
VCID: 3979CB6F73AC49D693D-5000
No fault code found.
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 F
Component: Lenksáulenmodul 0308
Coding: 01011
Shop #: WSC 00672
VCID: 3663C05312B2A6AE7EF-4A3A
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8H0 920 950 D
Component: KOMBI+WEGFAHRS. RB4 D16
Coding: 00401
Shop #: WSC 00001
VCID: 2D51EF3FE7E4E5760F5-5000
WAUZZZ8H83K021003 AUZ6Z0B0361089
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8H0 951 178
Component: Innenraumueberw. 0311
Coding: 00001
Shop #: WSC 00000
VCID: EFEDB537AD685766FD9-5072
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8H0 959 433 D
Component: Komfortgerát T3B 1210
Coding: 06795
Shop #: WSC 00672
VCID: 3561C75F0FB4ADB6775-4A9C
Subsystem 1 - Part No: 8H2959802
Component: Tõrsteuer.FS BRM 0001
Subsystem 2 - Part No: 8H2959801
Component: Tõrsteuer.BF BRM 0001
Subsystem 3 - Part No: 8H0959801A
Component: Tõrsteuer.HL BRM 1.60
Subsystem 4 - Part No: 8H0959802A
Component: Tõrsteuer.HR BRM 1.60
1 Fault Found:
01134 - Alarm Horn (H12)
29-00 - Short to Ground
End ---------------------------------------------------------------------
Just a few to be going on with !!!!!!!!!!
VCDS will not communicate with roof controller for some reason and roof electrics do nothing when switch pressed ? weird as it wa working fine till battery went flat!
67 69 75 76 77
Coding: 0011504
1 Fault Found:
Coding: 04475
Shop #: WSC 00672
1 Fault Found:
35-00 - -
Coding: 00100
Shop #: WSC 00672
2 Faults Found:
Coding: 00001
Shop #: WSC 00672
4 Faults Found:
Coding: 0011104
Coding: 01011
Shop #: WSC 00672
Coding: 00401
Shop #: WSC 00001
Coding: 00001
Shop #: WSC 00000
Coding: 06795
Shop #: WSC 00672
1 Fault Found:
