tony mc
Tfsi cam follower.
i thought it was a salt shaker lmao
Tfsi cam follower.
Well I've finally got them fitted.....still have to finish off putting a couple of brackets on for the brake pipes, wheels also need a good clean. They do look small now they are on though......
shiny, shiny .......very nice carl , you just need to give them wheels a darn good scrub to make them just as shiny...... come down and sort mine out next.
yeh any where closer than the other side of the country, ain't that far really mate, have a run out to bed your brakes in
Didn't fancy the purple ones then looks goodWell I've finally got them fitted.....still have to finish off putting a couple of brackets on for the brake pipes, wheels also need a good clean. They do look small now they are on though......
To be honest I thought I might think that but it hasn't shown through. It is quite thick the vinyl so I can only assume that's the reason
and mine lmao
the pattern?
I have a nice powerfull vacuum cleaner tony you can use so you can do something with your carpets.....your letting the side down now...lol
that's been off that many times prating about i aint bothered any more, i can class that as another mod, it makes shift's loads smoother,Right tony not only do you need to clean more often but you need to redo the gear stick bit again it's the wrong way round lol
yeh that's right, i did mine and only heated the edge's, so it wouldn't show through, worked very well on most of the trim, there is a few little bits where you can see it but mainly at the edge.
