Hi people, its been a long time since I've been on here audi has been behaving as it should be but a few weeks back it started to give me a serious problem which is
Basically the car starts ok when I turn the key however it dies straight away. I have to keep my foot on accelerator for a few minutes to keep the revs up then car is ok however idle set usually at 1ish, it also sounds like it's not running on all cylinders (Scooby sound) I've changed the spark plugs coil pack and also leads but still the problem persists. Once the car has warmed up it is perfectly fine and can put my foot down with out any problems, however if I turn the car off for an hour at least and return then the problem returns. It's really embarrassing when going starting the car as I have to rev it to 3 - 4 revs to keep the engine from dying again.
Please can some one help me with this, I've had the car for 8 years and this is the first time it's given me problems.
Any help will be appreciated.
Thank you.
Thank you.
