Hi,
I've got a '97 A3 8l 1.6 which recently got an issue where it would drop a couple of RPM's while running warm. It would mid-drive drop rpm and shock.
When warm it would also stall when running idle.
Reading it out with vcds it gave me a G28 sensor issue. So I bought a no-brand sensor off ebay. When it arrived I installed the sensor but it did't start at all. Replacing the old sensor would give the old results with starting and sensor error.
So I've bought a Bosch sensor 0261210147 (My original was 0261210148 but should have the same VAG product id). Unfortunately this could not get the engine running either. Now when I put back the original sensor it doesn't work either. I took out a spark plug and held it against the engine but it would not spark.
The car does crank though.
