A4 Balance shaft module Turbo problems
Optimusaudi
Hi
I hope I have posted in the correct section and please accept my apologies in advance if I haven't or due to my lack of knowledge.
I own Audi A4 2007, 2.0 litre Diesel s-line spec. Recently there has been white smoke coming out of the exhaust, as a result I had taken it to the Audi garage dor diagnostic and it turns out that the balance shaft turbo needs to be replaced which would cost me £1,800!!!!
From what I've read this is a common fault for models between 2005-2009. However, does anyone know what the cheapest option could be? Can I order this part somewhere cheaper? And just pay for labour? I'm really stuck at the moment. Thanks
Hi there, where abouts in the country are you ?
Reactions: Optimusaudi
Ok, give me a ring next week and if you can bring the car to Muswell Hill, N. London I would advise you what can be done. I am sure I can beat the quote that garage gave you... The balancer shaft upgrade is a good thing to do whilst engine is in bits however turbo is likely to have suffered from low oil pressure. Regards,
Chris 07789912128
Chris 07789912128
Hey Chris, thank you for the message. I will drop you a text soon.
I have my doubts about the turbo going because I feel the car wouldn't be a able to run. The car runs fine, but when it slows down that's when a little bit of white smoke comes out....
517
835
