mohammedzohaib
- Joined
- Jun 16, 2017
- Messages
- 10
- Reaction score
- 2
- Points
- 3
Hi,
Be gentle as im a newbie
My audi s3 2012 has started to over heat but only on idle. The temp reaches 110 before the fans kick in. I have plugged it into vagcom and there are no errors i have also done a output test on HVAC and ran the fan control module and both fans kick in but if i run the cooling fan it doesnt work. Now obviously you would say the cooling fan not working right? I then turned the car off and let it cool down. The next day i fired her up and let her warm up to 90c plugged her back in vag and did a measuring block test on the ENGINE section of vag. I watched the coolant temp rise to 103c and the cooling fan kicked in and dropped the temp. This is really confusing are they working or are they not its driving me mad. What could the problem be.
