I’ve retrofitted a FL camera unit to my PFL 2013 8v Sportback. For wiring I followed the retrofit tutorial Amit78 posted as well as coding instructions. Unfortunately nothing happens once I pop it into reverse.
By reading 6C advanced values I can see the camera is alive; system status changes to active when I put the car into reverse, steering angle changes etc. So I believe the issue is with 5F that’s not changing the display to show the camera output.
Here’s an auto scan:
Here’s the 5F adapDtion map:
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-STD1.clb
Part No SW: 8V0 035 840 A HW: 8V0 035 840
Component: MU-S--ER 039 0370
Serial number: A3E00504130867
Coding: 01730300FF00000011110001000A00002F0001040100010002
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_MUStd4CPASE 002018
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 336F30269A5FCFD75A-8066
Display unit 1 for multimedia system:
Subsystem 1 - Part No SW: 8V0 919 603 A HW: 8V0 919 603 A
Component: DU Std H47 0013
Serial number: AUZ8Z9DG600J1T
Multimedia Operating Unit:
Subsystem 2 - Part No SW: 8V0 919 614 B HW: 8V0 919 614 B
Component: ControlUnit_B H33 0037
Serial number: C1000022021300020072
No fault code found.
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
Part No SW: 5Q0 980 556 B HW: 5Q0 980 556 B
Component: RVC Compact H12 0231
Coding: 02730001A0010003000040
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
ROD: EV_CamSysRVRVCPANAMQBAB_006_VW37.rod
VCID: 3973020EB833358790-806C
1 Fault Found:
10489856 - No Basic Setting
B2010 00 [009] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 78
Mileage: 109384 km
Date: 2019.06.24
Time: 23:01:14
passive
End-------------------------(Elapsed Time: 03:45)--------------------------
1 Fault Found:
B2010 00 [009] - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 78
Mileage: 109384 km
Date: 2019.06.24
Time: 23:01:14
passive
;SW:8V0-035-840-A HW:8V0-035-840 --- Information Electr.
;Component:MU-S--ER 039 0370 Coding:01730300FF00000011110001000A00002F0001040100010002
;EV_MUStd4CPASE 2018 EV_MUStd4CPASE_VW37.rod
;Tuesday 25 June 2019 23:08:36:27303
;VCDS Version: Release 19.6.0 (x64) Data version: 20190529 DS308.0
;VCID: 336F30269A5FCFD75A-8066
IDE00001-Production mode 00 00 00 3
IDE00346-Summertime-automatic manual 1
IDE00758-Base volume of telephone 50% 1
IDE00759-Base volume of speech output 50% 1
IDE00760-Microphone sensitivity 6 dB 1
IDE00769-Number 1 for Info call 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 23
IDE00770-Number 1 for roadside assistance 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 23
IDE02121-CD eject button Enabled 1
IDE02122-Developer mode not activated 1
IDE02330-Number 2 for Info call 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 23
IDE02331-Number 2 for roadside assistance 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 23
IDE02332-Deactivate production mode 0 3
IDE02476-MAS03001-Electrical test of loudspeakers-Mode automatic 49
IDE02476-ENG117360-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency 19000 Hz 49
IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume 67 49
IDE02476-ENG117378-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency 19000 Hz 49
IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume 85 49
IDE02476-ENG117380-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency 19000 Hz 49
IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume 85 49
IDE02476-ENG117382-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency 19000 Hz 49
IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume 85 49
IDE02476-ENG117384-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency 19000 Hz 49
IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume 85 49
IDE02476-ENG117386-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency 19000 Hz 49
IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume 85 49
IDE02476-ENG117388-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency 19000 Hz 49
IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume 85 49
IDE02476-ENG117390-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency 19000 Hz 49
IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume 85 49
IDE02476-ENG117362-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency 19000 Hz 49
IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume 45 49
IDE02476-ENG117364-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency 19000 Hz 49
IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume 45 49
IDE02476-ENG117366-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency 19000 Hz 49
IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume 67 49
IDE02476-ENG117368-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency 19000 Hz 49
IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume 85 49
IDE02476-ENG117370-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency 19000 Hz 49
IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume 85 49
IDE02476-ENG117372-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency 19000 Hz 49
IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume 85 49
IDE02476-ENG117374-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency 19000 Hz 49
IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume 85 49
IDE02476-ENG117376-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency 19000 Hz 49
IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume 85 49
IDE02502-Confirmation of installation change A2 03 2
IDE02699-Number 1 for roadside assistance 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 23
IDE02701-Number 1 (roaming) for roadside assistance 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 23
IDE03581-ENG117690-Vehicle function list CAN-Adaptive_key_msg_bus Databus Infotainment 8
IDE03581-ENG117691-Vehicle function list CAN-Adaptive_key_school Available 8
IDE03581-ENG117688-Vehicle function list CAN-Driving_school Not available 8
IDE03581-ENG117689-Vehicle function list CAN-Driving_school_msg_bus Comfort data bus 8
IDE03581-ENG107608-Vehicle function list CAN-MFL Available 8
IDE03581-ENG117681-Vehicle function list CAN-MFL_msg_bus Databus Infotainment 8
IDE03581-ENG117683-Vehicle function list CAN-Oil_level Not available 8
IDE03581-ENG117684-Vehicle function list CAN-Oil_level_msg_bus Comfort data bus 8
IDE03581-ENG117685-Vehicle function list CAN-PDC_audio_lowering Not available 8
IDE03581-ENG117686-Vehicle function list CAN-PDC_audio_lowering_msg_bus Comfort data bus 8
IDE03581-ENG98994-Vehicle function list CAN-Trailer Not available 8
IDE03581-ENG117682-Vehicle function list CAN-Trailer_msg_bus Comfort data bus 8
IDE03581-ENG99892-Vehicle function list CAN-VIN Available 8
IDE03581-ENG117687-Vehicle function list CAN-VIN_msg_bus Databus Infotainment 8
IDE03902-Automatic ring break diagnostic No automatic start 1
IDE04292-Roadside assistance mode Corresponding setting in MMI 1
IDE04294-Number attempted dialing attempts for roadside assistance 3 1
IDE04300-ENG117486-Vehicle menu operation-menu_display_ACC not activated 40
IDE04300-ENG117490-Vehicle menu operation-menu_display_ACC_after_disclaimer not activated 40
IDE04300-ENG117487-Vehicle menu operation-menu_display_ACC_operation_clamp_15_off not activated 40
IDE04300-ENG117488-Vehicle menu operation-menu_display_ACC_over_threshold_high not activated 40
IDE04300-ENG117489-Vehicle menu operation-menu_display_ACC_standstill not activated 40
IDE04300-ENG117646-Vehicle menu operation-menu_display_adaptive_key activated 40
IDE04300-ENG117650-Vehicle menu operation-menu_display_adaptive_key_after_disclaimer not activated 40
IDE04300-ENG117647-Vehicle menu operation-menu_display_adaptive_key_clamp_15_off not activated 40
IDE04300-ENG117648-Vehicle menu operation-menu_display_adaptive_key_over_threshold_high activated 40
IDE04300-ENG117649-Vehicle menu operation-menu_display_adaptive_key_standstill not activated 40
IDE04300-ENG117591-Vehicle menu operation-menu_display_air_damper not activated 40
IDE04300-ENG117595-Vehicle menu operation-menu_display_air_damper_after_disclaimer not activated 40
IDE04300-ENG117592-Vehicle menu operation-menu_display_air_damper_clamp_15_off not activated 40
IDE04300-ENG117593-Vehicle menu operation-menu_display_air_damper_over_threshold_high not activated 40
IDE04300-ENG117594-Vehicle menu operation-menu_display_air_damper_standstill not activated 40
IDE04300-ENG117491-Vehicle menu operation-menu_display_ambient_illumination activated 40
IDE04300-ENG117495-Vehicle menu operation-menu_display_ambient_illumination_after_disclaimer not activated 40
IDE04300-ENG117492-Vehicle menu operation-menu_display_ambient_illumination_clamp_15_off not activated 40
IDE04300-ENG117493-Vehicle menu operation-menu_display_ambient_illumination_over_threshold_high activated 40
IDE04300-ENG117494-Vehicle menu operation-menu_display_ambient_illumination_standstill not activated 40
IDE04300-ENG117641-Vehicle menu operation-menu_display_attention_identification activated 40
IDE04300-ENG117645-Vehicle menu operation-menu_display_attention_identification_after_disclaimer not activated 40
IDE04300-ENG117642-Vehicle menu operation-menu_display_attention_identification_clamp_15_off not activated 40
IDE04300-ENG117643-Vehicle menu operation-menu_display_attention_identification_over_threshold_high activated 40
IDE04300-ENG117644-Vehicle menu operation-menu_display_attention_identification_standstill not activated 40
IDE04300-ENG117531-Vehicle menu operation-menu_display_auxiliary_heating not activated 40
IDE04300-ENG117535-Vehicle menu operation-menu_display_auxiliary_heating_after_disclaimer not activated 40
IDE04300-ENG117532-Vehicle menu operation-menu_display_auxiliary_heating_clamp_15_off not activated 40
IDE04300-ENG117533-Vehicle menu operation-menu_display_auxiliary_heating_over_threshold_high not activated 40
IDE04300-ENG117534-Vehicle menu operation-menu_display_auxiliary_heating_standstill not activated 40
IDE04300-ENG117501-Vehicle menu operation-menu_display_awv not activated 40
IDE04300-ENG117505-Vehicle menu operation-menu_display_awv_after_disclaimer not activated 40
IDE04300-ENG117502-Vehicle menu operation-menu_display_awv_clamp_15_off not activated 40
IDE04300-ENG117503-Vehicle menu operation-menu_display_awv_over_threshold_high not activated 40
IDE04300-ENG117504-Vehicle menu operation-menu_display_awv_standstill not activated 40
IDE04300-ENG117666-Vehicle menu operation-menu_display_BCmE not activated 40
IDE04300-ENG117670-Vehicle menu operation-menu_display_BCmE_after_disclaimer not activated 40
IDE04300-ENG117667-Vehicle menu operation-menu_display_BCmE_clamp_15_off not activated 40
IDE04300-ENG117668-Vehicle menu operation-menu_display_BCmE_over_threshold_high not activated 40
IDE04300-ENG117669-Vehicle menu operation-menu_display_BCmE_standstill not activated 40
IDE04300-ENG117536-Vehicle menu operation-menu_display_board_computer activated 40
IDE04300-ENG117540-Vehicle menu operation-menu_display_board_computer_after_disclaimer not activated 40
IDE04300-ENG117537-Vehicle menu operation-menu_display_board_computer_clamp_15_off not activated 40
IDE04300-ENG117538-Vehicle menu operation-menu_display_board_computer_over_threshold_high activated 40
IDE04300-ENG117539-Vehicle menu operation-menu_display_board_computer_standstill not activated 40
IDE04300-ENG117671-Vehicle menu operation-menu_display_Brake_Function not activated 40
IDE04300-ENG117675-Vehicle menu operation-menu_display_Brake_Function_after_disclaimer not activated 40
IDE04300-ENG117672-Vehicle menu operation-menu_display_Brake_Function_clamp_15_off not activated 40
IDE04300-ENG117673-Vehicle menu operation-menu_display_Brake_Function_over_threshold_high not activated 40
IDE04300-ENG117674-Vehicle menu operation-menu_display_Brake_Function_standstill not activated 40
IDE04300-ENG117651-Vehicle menu operation-menu_display_car_mirror not activated 40
IDE04300-ENG117655-Vehicle menu operation-menu_display_car_mirror_after_disclaimer not activated 40
IDE04300-ENG117652-Vehicle menu operation-menu_display_car_mirror_clamp_15_off not activated 40
IDE04300-ENG117653-Vehicle menu operation-menu_display_car_mirror_over_threshold_high not activated 40
IDE04300-ENG117654-Vehicle menu operation-menu_display_car_mirror_standstill not activated 40
IDE04300-ENG117561-Vehicle menu operation-menu_display_central_locking activated 40
IDE04300-ENG117565-Vehicle menu operation-menu_display_central_locking_after_disclaimer not activated 40
IDE04300-ENG117562-Vehicle menu operation-menu_display_central_locking_clamp_15_off not activated 40
IDE04300-ENG117563-Vehicle menu operation-menu_display_central_locking_over_threshold_high activated 40
IDE04300-ENG117564-Vehicle menu operation-menu_display_central_locking_standstill not activated 40
IDE04300-ENG117601-Vehicle menu operation-menu_display_central_unit_master activated 40
IDE04300-ENG117605-Vehicle menu operation-menu_display_central_unit_master_after_disclaimer not activated 40
IDE04300-ENG117602-Vehicle menu operation-menu_display_central_unit_master_clamp_15_off not activated 40
IDE04300-ENG117603-Vehicle menu operation-menu_display_central_unit_master_over_threshold_high activated 40
IDE04300-ENG117604-Vehicle menu operation-menu_display_central_unit_master_standstill not activated 40
IDE04300-ENG117571-Vehicle menu operation-menu_display_charisma not activated 40
IDE04300-ENG117575-Vehicle menu operation-menu_display_charisma_after_disclaimer not activated 40
IDE04300-ENG117572-Vehicle menu operation-menu_display_charisma_clamp_15_off not activated 40
IDE04300-ENG117573-Vehicle menu operation-menu_display_charisma_over_threshold_high not activated 40
IDE04300-ENG117574-Vehicle menu operation-menu_display_charisma_standstill not activated 40
IDE04300-ENG117526-Vehicle menu operation-menu_display_clima_configuration activated 40
IDE04300-ENG117530-Vehicle menu operation-menu_display_clima_configuration_after_disclaimer not activated 40
IDE04300-ENG117527-Vehicle menu operation-menu_display_clima_configuration_clamp_15_off not activated 40
IDE04300-ENG117528-Vehicle menu operation-menu_display_clima_configuration_over_threshold_high activated 40
IDE04300-ENG117529-Vehicle menu operation-menu_display_clima_configuration_standstill not activated 40
IDE04300-ENG117586-Vehicle menu operation-menu_display_clock activated 40
IDE04300-ENG117590-Vehicle menu operation-menu_display_clock_after_disclaimer not activated 40
IDE04300-ENG117587-Vehicle menu operation-menu_display_clock_clamp_15_off not activated 40
IDE04300-ENG117588-Vehicle menu operation-menu_display_clock_over_threshold_high activated 40
IDE04300-ENG117589-Vehicle menu operation-menu_display_clock_standstill not activated 40
IDE04300-ENG117566-Vehicle menu operation-menu_display_compass not activated 40
IDE04300-ENG117570-Vehicle menu operation-menu_display_compass_after_disclaimer not activated 40
IDE04300-ENG117567-Vehicle menu operation-menu_display_compass_clamp_15_off not activated 40
IDE04300-ENG117568-Vehicle menu operation-menu_display_compass_over_threshold_high not activated 40
IDE04300-ENG117569-Vehicle menu operation-menu_display_compass_standstill not activated 40
IDE04300-ENG117656-Vehicle menu operation-menu_display_driving_school not activated 40
IDE04300-ENG117660-Vehicle menu operation-menu_display_driving_school_after_disclaimer not activated 40
IDE04300-ENG117657-Vehicle menu operation-menu_display_driving_school_clamp_15_off not activated 40
IDE04300-ENG117658-Vehicle menu operation-menu_display_driving_school_over_threshold_high not activated 40
IDE04300-ENG117659-Vehicle menu operation-menu_display_driving_school_standstill not activated 40
IDE04300-ENG125034-Vehicle menu operation-menu_display_Ecall not activated 40
IDE04300-ENG125038-Vehicle menu operation-menu_display_Ecall_after_disclaimer not activated 40
IDE04300-ENG126999-Vehicle menu operation-menu_display_eCall_clamp_15_off not activated 40
IDE04300-ENG125036-Vehicle menu operation-menu_display_Ecall_over_threshold_high not activated 40
IDE04300-ENG125037-Vehicle menu operation-menu_display_Ecall_standstill not activated 40
IDE04300-ENG117516-Vehicle menu operation-menu_display_exterior_illumination activated 40
IDE04300-ENG117520-Vehicle menu operation-menu_display_exterior_illumination_after_disclaimer not activated 40
IDE04300-ENG117517-Vehicle menu operation-menu_display_exterior_illumination_clamp_15_off not activated 40
IDE04300-ENG117518-Vehicle menu operation-menu_display_exterior_illumination_over_threshold_high not activated 40
IDE04300-ENG117519-Vehicle menu operation-menu_display_exterior_illumination_standstill not activated 40
IDE04300-ENG117596-Vehicle menu operation-menu_display_headup_display not activated 40
IDE04300-ENG117600-Vehicle menu operation-menu_display_headup_display_after_disclaimer not activated 40
IDE04300-ENG117597-Vehicle menu operation-menu_display_headup_display_clamp_15_off not activated 40
IDE04300-ENG117598-Vehicle menu operation-menu_display_headup_display_over_threshold_high not activated 40
IDE04300-ENG117599-Vehicle menu operation-menu_display_headup_display_standstill not activated 40
IDE04300-ENG117606-Vehicle menu operation-menu_display_hybrid not activated 40
IDE04300-ENG117610-Vehicle menu operation-menu_display_hybrid_after_disclaimer not activated 40
IDE04300-ENG117607-Vehicle menu operation-menu_display_hybrid_clamp_15_off not activated 40
IDE04300-ENG117608-Vehicle menu operation-menu_display_hybrid_over_threshold_high not activated 40
IDE04300-ENG117609-Vehicle menu operation-menu_display_hybrid_standstill not activated 40
IDE04300-ENG117506-Vehicle menu operation-menu_display_Lane_Departure_Warning not activated 40
IDE04300-ENG117510-Vehicle menu operation-menu_display_Lane_Departure_Warning_after_disclaimer not activated 40
IDE04300-ENG117507-Vehicle menu operation-menu_display_Lane_Departure_Warning_clamp_15_off not activated 40
IDE04300-ENG117508-Vehicle menu operation-menu_display_Lane_Departure_Warning_over_threshold_high not activated 40
IDE04300-ENG117509-Vehicle menu operation-menu_display_Lane_Departure_Warning_standstill not activated 40
IDE04300-ENG117631-Vehicle menu operation-menu_display_MFL_jocker activated 40
IDE04300-ENG117635-Vehicle menu operation-menu_display_MFL_jocker_after_disclaimer not activated 40
IDE04300-ENG117632-Vehicle menu operation-menu_display_MFL_jocker_clamp_15_off not activated 40
IDE04300-ENG117633-Vehicle menu operation-menu_display_MFL_jocker_over_threshold_high activated 40
IDE04300-ENG117634-Vehicle menu operation-menu_display_MFL_jocker_standstill not activated 40
IDE04300-ENG117616-Vehicle menu operation-menu_display_night_vision not activated 40
IDE04300-ENG117620-Vehicle menu operation-menu_display_night_vision_after_disclaimer not activated 40
IDE04300-ENG117617-Vehicle menu operation-menu_display_night_vision_clamp_15_off not activated 40
IDE04300-ENG117618-Vehicle menu operation-menu_display_night_vision_over_threshold_high not activated 40
IDE04300-ENG117619-Vehicle menu operation-menu_display_night_vision_standstill not activated 40
IDE04300-ENG117576-Vehicle menu operation-menu_display_oil_level not activated 40
IDE04300-ENG117580-Vehicle menu operation-menu_display_oil_level_after_disclaimer not activated 40
IDE04300-ENG117577-Vehicle menu operation-menu_display_oil_level_clamp_15_off not activated 40
IDE04300-ENG117578-Vehicle menu operation-menu_display_oil_level_over_threshold_high not activated 40
IDE04300-ENG117579-Vehicle menu operation-menu_display_oil_level_standstill not activated 40
IDE04300-ENG117496-Vehicle menu operation-menu_display_pdc not activated 40
IDE04300-ENG117500-Vehicle menu operation-menu_display_pdc_after_disclaimer not activated 40
IDE04300-ENG117497-Vehicle menu operation-menu_display_pdc_clamp_15_off not activated 40
IDE04300-ENG117498-Vehicle menu operation-menu_display_pdc_over_threshold_high not activated 40
IDE04300-ENG117499-Vehicle menu operation-menu_display_pdc_standstill not activated 40
IDE04300-ENG117541-Vehicle menu operation-menu_display_rdk not activated 40
IDE04300-ENG117545-Vehicle menu operation-menu_display_rdk_after_disclaimer not activated 40
IDE04300-ENG117542-Vehicle menu operation-menu_display_rdk_clamp_15_off not activated 40
IDE04300-ENG117543-Vehicle menu operation-menu_display_rdk_over_threshold_high not activated 40
IDE04300-ENG117544-Vehicle menu operation-menu_display_rdk_standstill not activated 40
IDE04300-ENG117626-Vehicle menu operation-menu_display_reversible_belt_pre_load not activated 40
IDE04300-ENG117630-Vehicle menu operation-menu_display_reversible_belt_pre_load_after_disclaimer not activated 40
IDE04300-ENG117627-Vehicle menu operation-menu_display_reversible_belt_pre_load_clamp_15_off not activated 40
IDE04300-ENG117628-Vehicle menu operation-menu_display_reversible_belt_pre_load_over_threshold_high not activated 40
IDE04300-ENG117629-Vehicle menu operation-menu_display_reversible_belt_pre_load_standstill not activated 40
IDE04300-ENG117636-Vehicle menu operation-menu_display_road_sign_identification not activated 40
IDE04300-ENG117640-Vehicle menu operation-menu_display_road_sign_identification_after_disclaimer not activated 40
IDE04300-ENG117637-Vehicle menu operation-menu_display_road_sign_identification_clamp_15_off not activated 40
IDE04300-ENG117638-Vehicle menu operation-menu_display_road_sign_identification_over_threshold_high not activated 40
IDE04300-ENG117639-Vehicle menu operation-menu_display_road_sign_identification_standstill not activated 40
IDE04300-ENG117556-Vehicle menu operation-menu_display_seat_configuration not activated 40
IDE04300-ENG117560-Vehicle menu operation-menu_display_seat_configuration_after_disclaimer not activated 40
IDE04300-ENG117557-Vehicle menu operation-menu_display_seat_configuration_clamp_15_off not activated 40
IDE04300-ENG117558-Vehicle menu operation-menu_display_seat_configuration_over_threshold_high not activated 40
IDE04300-ENG117559-Vehicle menu operation-menu_display_seat_configuration_standstill not activated 40
IDE04300-ENG117551-Vehicle menu operation-menu_display_sia activated 40
IDE04300-ENG117555-Vehicle menu operation-menu_display_sia_after_disclaimer not activated 40
IDE04300-ENG117552-Vehicle menu operation-menu_display_sia_clamp_15_off not activated 40
IDE04300-ENG117553-Vehicle menu operation-menu_display_sia_over_threshold_high activated 40
IDE04300-ENG117554-Vehicle menu operation-menu_display_sia_standstill not activated 40
IDE04300-ENG117511-Vehicle menu operation-menu_display_side_assistant not activated 40
IDE04300-ENG117515-Vehicle menu operation-menu_display_side_assistant_after_disclaimer not activated 40
IDE04300-ENG117512-Vehicle menu operation-menu_display_side_assistant_clamp_15_off not activated 40
IDE04300-ENG117513-Vehicle menu operation-menu_display_side_assistant_over_threshold_high not activated 40
IDE04300-ENG117514-Vehicle menu operation-menu_display_side_assistant_standstill not activated 40
IDE04300-ENG117621-Vehicle menu operation-menu_display_side_view not activated 40
IDE04300-ENG117625-Vehicle menu operation-menu_display_side_view_after_disclaimer not activated 40
IDE04300-ENG117622-Vehicle menu operation-menu_display_side_view_clamp_15_off not activated 40
IDE04300-ENG117623-Vehicle menu operation-menu_display_side_view_over_threshold_high not activated 40
IDE04300-ENG117624-Vehicle menu operation-menu_display_side_view_standstill not activated 40
IDE04300-ENG117676-Vehicle menu operation-menu_display_Start_Stop_reasons not activated 40
IDE04300-ENG117680-Vehicle menu operation-menu_display_Start_Stop_reasons_after_disclaimer not activated 40
IDE04300-ENG117677-Vehicle menu operation-menu_display_Start_Stop_reasons_clamp_15_off not activated 40
IDE04300-ENG117678-Vehicle menu operation-menu_display_Start_Stop_reasons_over_threshold_high not activated 40
IDE04300-ENG117679-Vehicle menu operation-menu_display_Start_Stop_reasons_standstill not activated 40
IDE04300-ENG117611-Vehicle menu operation-menu_display_ugdo not activated 40
IDE04300-ENG117615-Vehicle menu operation-menu_display_ugdo_after_disclaimer not activated 40
IDE04300-ENG117612-Vehicle menu operation-menu_display_ugdo_clamp_15_off not activated 40
IDE04300-ENG117613-Vehicle menu operation-menu_display_ugdo_over_threshold_high not activated 40
IDE04300-ENG117614-Vehicle menu operation-menu_display_ugdo_standstill not activated 40
IDE04300-ENG117581-Vehicle menu operation-menu_display_vin activated 40
IDE04300-ENG117585-Vehicle menu operation-menu_display_vin_after_disclaimer not activated 40
IDE04300-ENG117582-Vehicle menu operation-menu_display_vin_clamp_15_off not activated 40
IDE04300-ENG117583-Vehicle menu operation-menu_display_vin_over_threshold_high activated 40
IDE04300-ENG117584-Vehicle menu operation-menu_display_vin_standstill not activated 40
IDE04300-ENG117661-Vehicle menu operation-menu_display_weariness_recognition activated 40
IDE04300-ENG117665-Vehicle menu operation-menu_display_weariness_recognition_after_disclaimer not activated 40
IDE04300-ENG117662-Vehicle menu operation-menu_display_weariness_recognition_clamp_15_off not activated 40
IDE04300-ENG117663-Vehicle menu operation-menu_display_weariness_recognition_over_threshold_high activated 40
IDE04300-ENG117664-Vehicle menu operation-menu_display_weariness_recognition_standstill not activated 40
IDE04300-ENG117521-Vehicle menu operation-menu_display_windows not activated 40
IDE04300-ENG117525-Vehicle menu operation-menu_display_windows_after_disclaimer not activated 40
IDE04300-ENG117522-Vehicle menu operation-menu_display_windows_clamp_15_off not activated 40
IDE04300-ENG117523-Vehicle menu operation-menu_display_windows_over_threshold_high not activated 40
IDE04300-ENG117524-Vehicle menu operation-menu_display_windows_standstill not activated 40
IDE04300-ENG117546-Vehicle menu operation-menu_display_wiper not activated 40
IDE04300-ENG117550-Vehicle menu operation-menu_display_wiper_after_disclaimer not activated 40
IDE04300-ENG117547-Vehicle menu operation-menu_display_wiper_clamp_15_off not activated 40
IDE04300-ENG117548-Vehicle menu operation-menu_display_wiper_over_threshold_high not activated 40
IDE04300-ENG117549-Vehicle menu operation-menu_display_wiper_standstill not activated 40
IDE04307-ENG117700-Vehicle function list BAP-ACC_0x05 not activated 53
IDE04307-ENG117701-Vehicle function list BAP-ACC_0x05_msg_bus Comfort data bus 53
IDE04307-ENG117702-Vehicle function list BAP-air_suspension_0x06 not activated 53
IDE04307-ENG117703-Vehicle function list BAP-air_suspension_0x06_msg_bus Comfort data bus 53
IDE04307-ENG117764-Vehicle function list BAP-Amplifier_0x2D not activated 53
IDE04307-ENG117765-Vehicle function list BAP-Amplifier_0x2D_msg_bus Comfort data bus 53
IDE04307-ENG117696-Vehicle function list BAP-auxilary_heating_0x03 not activated 53
IDE04307-ENG117697-Vehicle function list BAP-auxilary_heating_0x03_msg_bus Comfort data bus 53
IDE04307-ENG117744-Vehicle function list BAP-AWV_0x1B not activated 53
IDE04307-ENG117745-Vehicle function list BAP-AWV_0x1B_msg_bus Comfort data bus 53
IDE04307-ENG117758-Vehicle function list BAP-BCmE_0x23 not activated 53
IDE04307-ENG117759-Vehicle function list BAP-BCmE_0x23_msg_bus Comfort data bus 53
IDE04307-ENG117760-Vehicle function list BAP-Brake_0x26 not activated 53
IDE04307-ENG117761-Vehicle function list BAP-Brake_0x26_msg_bus Comfort data bus 53
IDE04307-ENG117717-Vehicle function list BAP-central_locking_0x0D activated 53
IDE04307-ENG117716-Vehicle function list BAP-central_locking_0x0D_msg_bus Comfort data bus 53
IDE04307-ENG117736-Vehicle function list BAP-charisma_0x17 not activated 53
IDE04307-ENG117737-Vehicle function list BAP-charisma_0x17_msg_bus Comfort data bus 53
IDE04307-ENG117734-Vehicle function list BAP-clima_slave_2_0x16 not activated 53
IDE04307-ENG117735-Vehicle function list BAP-clima_slave_2_0x16_msg_bus Comfort data bus 53
IDE04307-ENG117692-Vehicle function list BAP-climatic_master_0x01 activated 53
IDE04307-ENG117693-Vehicle function list BAP-climatic_master_0x01_msg_bus Comfort data bus 53
IDE04307-ENG117694-Vehicle function list BAP-climatic_slave_0x02 not activated 53
IDE04307-ENG117695-Vehicle function list BAP-climatic_slave_0x02_msg_bus Comfort data bus 53
IDE04307-ENG117724-Vehicle function list BAP-clock_0x11 activated 53
IDE04307-ENG117725-Vehicle function list BAP-clock_0x11_msg_bus Comfort data bus 53
IDE04307-ENG117732-Vehicle function list BAP-compass_0x15 not activated 53
IDE04307-ENG117733-Vehicle function list BAP-compass_0x15_msg_bus Comfort data bus 53
IDE04307-ENG117722-Vehicle function list BAP-driver_seat_0x10 not activated 53
IDE04307-ENG117723-Vehicle function list BAP-driver_seat_0x10_msg_bus Comfort data bus 53
IDE04307-ENG125039-Vehicle function list BAP-Ecall_0x33 not activated 53
IDE04307-ENG125040-Vehicle function list BAP-Ecall_msg_bus_0x33 Comfort data bus 53
IDE04307-ENG117708-Vehicle function list BAP-exterieur_light_0x09 activated 53
IDE04307-ENG117709-Vehicle function list BAP-exterieur_light_0x09_msg_bus Comfort data bus 53
IDE04307-ENG117698-Vehicle function list BAP-headup_displ_0x04 not activated 53
IDE04307-ENG117699-Vehicle function list BAP-headup_displ_0x04_msg_bus Comfort data bus 53
IDE04307-ENG117746-Vehicle function list BAP-Hybrid_0x1D not activated 53
IDE04307-ENG117747-Vehicle function list BAP-Hybrid_0x1D_msg_bus Comfort data bus 53
IDE04307-ENG117706-Vehicle function list BAP-interieur_light_0x08 activated 53
IDE04307-ENG117707-Vehicle function list BAP-interieur_light_0x08_msg_bus Comfort data bus 53
IDE04307-ENG117740-Vehicle function list BAP-LDW_HCA_0x19 not activated 53
IDE04307-ENG117741-Vehicle function list BAP-LDW_HCA_0x19_msg_bus Comfort data bus 53
IDE04307-ENG117720-Vehicle function list BAP-MFA_0x0F activated 53
IDE04307-ENG117721-Vehicle function list BAP-MFA_0x0F_msg_bus Comfort data bus 53
IDE04307-ENG117767-Vehicle function list BAP-MFL_Jocker_0x34 activated 53
IDE04307-ENG117766-Vehicle function list BAP-MFL_Jocker_msg_bus_0x34 Databus Infotainment 53
IDE04307-ENG117719-Vehicle function list BAP-mirror_0x0E not activated 53
IDE04307-ENG117718-Vehicle function list BAP-mirror_0x0E_msg_bus Comfort data bus 53
IDE04307-ENG117738-Vehicle function list BAP-Night_Vision_0x18 not activated 53
IDE04307-ENG117739-Vehicle function list BAP-Night_Vision_0x18_msg_bus Comfort data bus 53
IDE04307-ENG117710-Vehicle function list BAP-parking_assist_0x0A not activated 53
IDE04307-ENG117711-Vehicle function list BAP-parking_assist_0x0A_msg_bus Not available 53
IDE04307-ENG117752-Vehicle function list BAP-Passenger_Seat_0x20 not activated 53
IDE04307-ENG117753-Vehicle function list BAP-Passenger_Seat_0x20_msg_bus Comfort data bus 53
IDE04307-ENG117750-Vehicle function list BAP-Reversible_Seat_Belt_Tightener_0x1F not activated 53
IDE04307-ENG117751-Vehicle function list BAP-Reversible_Seat_Belt_Tightener_0x1F_msg_bus Comfort data bus 53
IDE04307-ENG117726-Vehicle function list BAP-service_interval_display_0x12 activated 53
IDE04307-ENG117727-Vehicle function list BAP-service_interval_display_0x12_msg_bus Comfort data bus 53
IDE04307-ENG117748-Vehicle function list BAP-SideView_0x1E not activated 53
IDE04307-ENG117749-Vehicle function list BAP-SideView_0x1E_msg_bus Comfort data bus 53
IDE04307-ENG117762-Vehicle function list BAP-Start_Stop_reasons_0x27 not activated 53
IDE04307-ENG117763-Vehicle function list BAP-Start_Stop_reasons_0x27_msg_bus Comfort data bus 53
IDE04307-ENG117742-Vehicle function list BAP-SWA_0x1A not activated 53
IDE04307-ENG117743-Vehicle function list BAP-SWA_0x1A_msg_bus Comfort data bus 53
IDE04307-ENG117704-Vehicle function list BAP-tire_pressure_system_0x07 not activated 53
IDE04307-ENG117705-Vehicle function list BAP-tire_pressure_system_0x07_msg_bus Comfort data bus 53
IDE04307-ENG117754-Vehicle function list BAP-traffic_sign_recognition_0x21 not activated 53
IDE04307-ENG117755-Vehicle function list BAP-traffic_sign_recognition_0x21_msg_bus Comfort data bus 53
IDE04307-ENG117730-Vehicle function list BAP-UGDO_0x14 not activated 53
IDE04307-ENG117731-Vehicle function list BAP-UGDO_0x14_msg_bus Comfort data bus 53
IDE04307-ENG117728-Vehicle function list BAP-unit_master_0x13 activated 53
IDE04307-ENG117729-Vehicle function list BAP-unit_master_0x13_msg_bus Comfort data bus 53
IDE04307-ENG117712-Vehicle function list BAP-VPS_0x0B activated 53
IDE04307-ENG117713-Vehicle function list BAP-VPS_0x0B_msg_bus Comfort data bus 53
IDE04307-ENG117756-Vehicle function list BAP-weariness_rcognition_0x22 activated 53
IDE04307-ENG117757-Vehicle function list BAP-weariness_rcognition_0x22_msg_bus Databus Infotainment 53
IDE04307-ENG117714-Vehicle function list BAP-wiper_comfort_0x0C not activated 53
IDE04307-ENG117715-Vehicle function list BAP-wiper_comfort_0x0C_msg_bus Comfort data bus 53
IDE04330-Transfer of release code for a SWaP function 0 1
IDE04331-Selection of release codes for a SWaP function FF FF FF FF 4
IDE04521-Sporadic ring break detection Visual 1
IDE04522-Awakening ability on optical databus OFF 1
IDE04550-Bluetooth: Sniff mode OFF 1
IDE05112-MAS02228-Image position-X coordinate 0 2
IDE05112-MAS02229-Image position-Y coordinate 0 2
IDE05113-Infotainment Recorder activated 1
IDE06698-MAS00839-Audio management input gain-TV Tuner -128 dB 6
IDE06698-MAS00846-Audio management input gain-Satellite radio -128 dB 6
IDE06698-MAS01984-Audio management input gain-Radio (FM) -128 dB 6
IDE06698-MAS01985-Audio management input gain-Radio (AM) -128 dB 6
IDE06698-MAS01986-Audio management input gain-Digital radio (DAB) -128 dB 6
MAS00951-Bluetooth On 1
MAS01968-Fan normal 1
MAS02809-MAS02870-Check tone frequency-High note frequency range 4000 Hz 6
MAS02809-MAS02871-Check tone frequency-Medium note frequency range 1000 Hz 6
MAS02809-MAS02872-Check tone frequency-Low note frequency range 100 Hz 6
ENG117917-BAP_Debug_Mode_Release not_released 1
ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_Unit-X1 0 6
ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2 50 6
ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3 100 6
ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_Unit-Y1 0 6
ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2 50 6
ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3 100 6
ENG117914-ENG101574-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X1 0 6
ENG117914-ENG99557-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X2 50 6
ENG117914-ENG102140-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X3 100 6
ENG117914-ENG99777-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y1 0 6
ENG117914-ENG100480-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y2 50 6
ENG117914-ENG100773-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y3 100 6
ENG117915-ENG101574-Dimming_Functional_Illumination_for_Operating_Unit-X1 0 12
ENG117915-ENG99557-Dimming_Functional_Illumination_for_Operating_Unit-X2 10 12
ENG117915-ENG102140-Dimming_Functional_Illumination_for_Operating_Unit-X3 100 12
ENG117915-ENG102936-Dimming_Functional_Illumination_for_Operating_Unit-X4 150 12
ENG117915-ENG103548-Dimming_Functional_Illumination_for_Operating_Unit-X5 220 12
ENG117915-ENG113992-Dimming_Functional_Illumination_for_Operating_Unit-X6 253 12
ENG117915-ENG99777-Dimming_Functional_Illumination_for_Operating_Unit-Y1 0% 12
ENG117915-ENG100480-Dimming_Functional_Illumination_for_Operating_Unit-Y2 6% 12
ENG117915-ENG100773-Dimming_Functional_Illumination_for_Operating_Unit-Y3 16% 12
ENG117915-ENG100631-Dimming_Functional_Illumination_for_Operating_Unit-Y4 30% 12
ENG117915-ENG102174-Dimming_Functional_Illumination_for_Operating_Unit-Y5 60% 12
ENG117915-ENG113993-Dimming_Functional_Illumination_for_Operating_Unit-Y6 100% 12
ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1 0 12
ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2 10 12
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3 50 12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4 100 12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5 150 12
ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6 253 12
ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1 1% 12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2 2% 12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3 4% 12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4 11% 12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5 30% 12
ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6 100% 12
ENG117809-p_damping_Display 5 ms 1
ENG117808-p_HMI_Display 10% 1
ENG117906-Shift_Remote_Test_Volume Default 1
Elapsed Time: 00:26
Elapsed Time: 00:26
