Rear view camera retrofit doesn’t work
Fraysa
27
AUDI
I’ve retrofitted a FL camera unit to my PFL 2013 8v Sportback. For wiring I followed the retrofit tutorial Amit78 posted as well as coding instructions. Unfortunately nothing happens once I pop it into reverse.
By reading 6C advanced values I can see the camera is alive; system status changes to active when I put the car into reverse, steering angle changes etc. So I believe the issue is with 5F that’s not changing the display to show the camera output.
Here’s an auto scan:
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-STD1.clb
Part No SW: 8V0 035 840 A HW: 8V0 035 840
Component: MU-S--ER 039 0370
Serial number: A3E00504130867
Coding: 01730300FF00000011110001000A00002F0001040100010002
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_MUStd4CPASE 002018
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 336F30269A5FCFD75A-8066
Display unit 1 for multimedia system:
Subsystem 1 - Part No SW: 8V0 919 603 A HW: 8V0 919 603 A
Component: DU Std H47 0013
Serial number: AUZ8Z9DG600J1T
Multimedia Operating Unit:
Subsystem 2 - Part No SW: 8V0 919 614 B HW: 8V0 919 614 B
Component: ControlUnit_B H33 0037
Serial number: C1000022021300020072
No fault code found.
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
Part No SW: 5Q0 980 556 B HW: 5Q0 980 556 B
Component: RVC Compact H12 0231
Coding: 02730001A0010003000040
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
ROD: EV_CamSysRVRVCPANAMQBAB_006_VW37.rod
VCID: 3973020EB833358790-806C
1 Fault Found:
10489856 - No Basic Setting
B2010 00 [009] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 78
Mileage: 109384 km
Date: 2019.06.24
Time: 23:01:14
passive
End-------------------------(Elapsed Time: 03:45)--------------------------
Here’s the 5F adapDtion map:
;SW:8V0-035-840-A HW:8V0-035-840 --- Information Electr.
;Component:MU-S--ER 039 0370 Coding:01730300FF00000011110001000A00002F0001040100010002
;EV_MUStd4CPASE 2018 EV_MUStd4CPASE_VW37.rod
;Tuesday 25 June 2019 23:08:36:27303
;VCDS Version: Release 19.6.0 (x64) Data version: 20190529 DS308.0
;VCID: 336F30269A5FCFD75A-8066
IDE00001-Production mode 00 00 00 3
IDE00346-Summertime-automatic manual 1
IDE00758-Base volume of telephone 50% 1
IDE00759-Base volume of speech output 50% 1
IDE00760-Microphone sensitivity 6 dB 1
IDE00769-Number 1 for Info call 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 23
IDE00770-Number 1 for roadside assistance 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 23
IDE02121-CD eject button Enabled 1
IDE02122-Developer mode not activated 1
IDE02330-Number 2 for Info call 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 23
IDE02331-Number 2 for roadside assistance 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 23
IDE02332-Deactivate production mode 0 3
IDE02476-MAS03001-Electrical test of loudspeakers-Mode automatic 49
IDE02476-ENG117360-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency 19000 Hz 49
IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume 67 49
IDE02476-ENG117378-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency 19000 Hz 49
IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume 85 49
IDE02476-ENG117380-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency 19000 Hz 49
IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume 85 49
IDE02476-ENG117382-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency 19000 Hz 49
IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume 85 49
IDE02476-ENG117384-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency 19000 Hz 49
IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume 85 49
IDE02476-ENG117386-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency 19000 Hz 49
IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume 85 49
IDE02476-ENG117388-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency 19000 Hz 49
IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume 85 49
IDE02476-ENG117390-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency 19000 Hz 49
IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume 85 49
IDE02476-ENG117362-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency 19000 Hz 49
IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume 45 49
IDE02476-ENG117364-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency 19000 Hz 49
IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume 45 49
IDE02476-ENG117366-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency 19000 Hz 49
IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume 67 49
IDE02476-ENG117368-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency 19000 Hz 49
IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume 85 49
IDE02476-ENG117370-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency 19000 Hz 49
IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume 85 49
IDE02476-ENG117372-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency 19000 Hz 49
IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume 85 49
IDE02476-ENG117374-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency 19000 Hz 49
IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume 85 49
IDE02476-ENG117376-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency 19000 Hz 49
IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume 85 49
IDE02502-Confirmation of installation change A2 03 2
IDE02699-Number 1 for roadside assistance 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 23
IDE02701-Number 1 (roaming) for roadside assistance 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 23
IDE03581-ENG117690-Vehicle function list CAN-Adaptive_key_msg_bus Databus Infotainment 8
IDE03581-ENG117691-Vehicle function list CAN-Adaptive_key_school Available 8
IDE03581-ENG117688-Vehicle function list CAN-Driving_school Not available 8
IDE03581-ENG117689-Vehicle function list CAN-Driving_school_msg_bus Comfort data bus 8
IDE03581-ENG107608-Vehicle function list CAN-MFL Available 8
IDE03581-ENG117681-Vehicle function list CAN-MFL_msg_bus Databus Infotainment 8
IDE03581-ENG117683-Vehicle function list CAN-Oil_level Not available 8
IDE03581-ENG117684-Vehicle function list CAN-Oil_level_msg_bus Comfort data bus 8
IDE03581-ENG117685-Vehicle function list CAN-PDC_audio_lowering Not available 8
IDE03581-ENG117686-Vehicle function list CAN-PDC_audio_lowering_msg_bus Comfort data bus 8
IDE03581-ENG98994-Vehicle function list CAN-Trailer Not available 8
IDE03581-ENG117682-Vehicle function list CAN-Trailer_msg_bus Comfort data bus 8
IDE03581-ENG99892-Vehicle function list CAN-VIN Available 8
IDE03581-ENG117687-Vehicle function list CAN-VIN_msg_bus Databus Infotainment 8
IDE03902-Automatic ring break diagnostic No automatic start 1
IDE04292-Roadside assistance mode Corresponding setting in MMI 1
IDE04294-Number attempted dialing attempts for roadside assistance 3 1
IDE04300-ENG117486-Vehicle menu operation-menu_display_ACC not activated 40
IDE04300-ENG117490-Vehicle menu operation-menu_display_ACC_after_disclaimer not activated 40
IDE04300-ENG117487-Vehicle menu operation-menu_display_ACC_operation_clamp_15_off not activated 40
IDE04300-ENG117488-Vehicle menu operation-menu_display_ACC_over_threshold_high not activated 40
IDE04300-ENG117489-Vehicle menu operation-menu_display_ACC_standstill not activated 40
IDE04300-ENG117646-Vehicle menu operation-menu_display_adaptive_key activated 40
IDE04300-ENG117650-Vehicle menu operation-menu_display_adaptive_key_after_disclaimer not activated 40
IDE04300-ENG117647-Vehicle menu operation-menu_display_adaptive_key_clamp_15_off not activated 40
IDE04300-ENG117648-Vehicle menu operation-menu_display_adaptive_key_over_threshold_high activated 40
IDE04300-ENG117649-Vehicle menu operation-menu_display_adaptive_key_standstill not activated 40
IDE04300-ENG117591-Vehicle menu operation-menu_display_air_damper not activated 40
IDE04300-ENG117595-Vehicle menu operation-menu_display_air_damper_after_disclaimer not activated 40
IDE04300-ENG117592-Vehicle menu operation-menu_display_air_damper_clamp_15_off not activated 40
IDE04300-ENG117593-Vehicle menu operation-menu_display_air_damper_over_threshold_high not activated 40
IDE04300-ENG117594-Vehicle menu operation-menu_display_air_damper_standstill not activated 40
IDE04300-ENG117491-Vehicle menu operation-menu_display_ambient_illumination activated 40
IDE04300-ENG117495-Vehicle menu operation-menu_display_ambient_illumination_after_disclaimer not activated 40
IDE04300-ENG117492-Vehicle menu operation-menu_display_ambient_illumination_clamp_15_off not activated 40
IDE04300-ENG117493-Vehicle menu operation-menu_display_ambient_illumination_over_threshold_high activated 40
IDE04300-ENG117494-Vehicle menu operation-menu_display_ambient_illumination_standstill not activated 40
IDE04300-ENG117641-Vehicle menu operation-menu_display_attention_identification activated 40
IDE04300-ENG117645-Vehicle menu operation-menu_display_attention_identification_after_disclaimer not activated 40
IDE04300-ENG117642-Vehicle menu operation-menu_display_attention_identification_clamp_15_off not activated 40
IDE04300-ENG117643-Vehicle menu operation-menu_display_attention_identification_over_threshold_high activated 40
IDE04300-ENG117644-Vehicle menu operation-menu_display_attention_identification_standstill not activated 40
IDE04300-ENG117531-Vehicle menu operation-menu_display_auxiliary_heating not activated 40
IDE04300-ENG117535-Vehicle menu operation-menu_display_auxiliary_heating_after_disclaimer not activated 40
IDE04300-ENG117532-Vehicle menu operation-menu_display_auxiliary_heating_clamp_15_off not activated 40
IDE04300-ENG117533-Vehicle menu operation-menu_display_auxiliary_heating_over_threshold_high not activated 40
IDE04300-ENG117534-Vehicle menu operation-menu_display_auxiliary_heating_standstill not activated 40
IDE04300-ENG117501-Vehicle menu operation-menu_display_awv not activated 40
IDE04300-ENG117505-Vehicle menu operation-menu_display_awv_after_disclaimer not activated 40
IDE04300-ENG117502-Vehicle menu operation-menu_display_awv_clamp_15_off not activated 40
IDE04300-ENG117503-Vehicle menu operation-menu_display_awv_over_threshold_high not activated 40
IDE04300-ENG117504-Vehicle menu operation-menu_display_awv_standstill not activated 40
IDE04300-ENG117666-Vehicle menu operation-menu_display_BCmE not activated 40
IDE04300-ENG117670-Vehicle menu operation-menu_display_BCmE_after_disclaimer not activated 40
IDE04300-ENG117667-Vehicle menu operation-menu_display_BCmE_clamp_15_off not activated 40
IDE04300-ENG117668-Vehicle menu operation-menu_display_BCmE_over_threshold_high not activated 40
IDE04300-ENG117669-Vehicle menu operation-menu_display_BCmE_standstill not activated 40
IDE04300-ENG117536-Vehicle menu operation-menu_display_board_computer activated 40
IDE04300-ENG117540-Vehicle menu operation-menu_display_board_computer_after_disclaimer not activated 40
IDE04300-ENG117537-Vehicle menu operation-menu_display_board_computer_clamp_15_off not activated 40
IDE04300-ENG117538-Vehicle menu operation-menu_display_board_computer_over_threshold_high activated 40
IDE04300-ENG117539-Vehicle menu operation-menu_display_board_computer_standstill not activated 40
IDE04300-ENG117671-Vehicle menu operation-menu_display_Brake_Function not activated 40
IDE04300-ENG117675-Vehicle menu operation-menu_display_Brake_Function_after_disclaimer not activated 40
IDE04300-ENG117672-Vehicle menu operation-menu_display_Brake_Function_clamp_15_off not activated 40
IDE04300-ENG117673-Vehicle menu operation-menu_display_Brake_Function_over_threshold_high not activated 40
IDE04300-ENG117674-Vehicle menu operation-menu_display_Brake_Function_standstill not activated 40
IDE04300-ENG117651-Vehicle menu operation-menu_display_car_mirror not activated 40
IDE04300-ENG117655-Vehicle menu operation-menu_display_car_mirror_after_disclaimer not activated 40
IDE04300-ENG117652-Vehicle menu operation-menu_display_car_mirror_clamp_15_off not activated 40
IDE04300-ENG117653-Vehicle menu operation-menu_display_car_mirror_over_threshold_high not activated 40
IDE04300-ENG117654-Vehicle menu operation-menu_display_car_mirror_standstill not activated 40
IDE04300-ENG117561-Vehicle menu operation-menu_display_central_locking activated 40
IDE04300-ENG117565-Vehicle menu operation-menu_display_central_locking_after_disclaimer not activated 40
IDE04300-ENG117562-Vehicle menu operation-menu_display_central_locking_clamp_15_off not activated 40
IDE04300-ENG117563-Vehicle menu operation-menu_display_central_locking_over_threshold_high activated 40
IDE04300-ENG117564-Vehicle menu operation-menu_display_central_locking_standstill not activated 40
IDE04300-ENG117601-Vehicle menu operation-menu_display_central_unit_master activated 40
IDE04300-ENG117605-Vehicle menu operation-menu_display_central_unit_master_after_disclaimer not activated 40
IDE04300-ENG117602-Vehicle menu operation-menu_display_central_unit_master_clamp_15_off not activated 40
IDE04300-ENG117603-Vehicle menu operation-menu_display_central_unit_master_over_threshold_high activated 40
IDE04300-ENG117604-Vehicle menu operation-menu_display_central_unit_master_standstill not activated 40
IDE04300-ENG117571-Vehicle menu operation-menu_display_charisma not activated 40
IDE04300-ENG117575-Vehicle menu operation-menu_display_charisma_after_disclaimer not activated 40
IDE04300-ENG117572-Vehicle menu operation-menu_display_charisma_clamp_15_off not activated 40
IDE04300-ENG117573-Vehicle menu operation-menu_display_charisma_over_threshold_high not activated 40
IDE04300-ENG117574-Vehicle menu operation-menu_display_charisma_standstill not activated 40
IDE04300-ENG117526-Vehicle menu operation-menu_display_clima_configuration activated 40
IDE04300-ENG117530-Vehicle menu operation-menu_display_clima_configuration_after_disclaimer not activated 40
IDE04300-ENG117527-Vehicle menu operation-menu_display_clima_configuration_clamp_15_off not activated 40
IDE04300-ENG117528-Vehicle menu operation-menu_display_clima_configuration_over_threshold_high activated 40
IDE04300-ENG117529-Vehicle menu operation-menu_display_clima_configuration_standstill not activated 40
IDE04300-ENG117586-Vehicle menu operation-menu_display_clock activated 40
IDE04300-ENG117590-Vehicle menu operation-menu_display_clock_after_disclaimer not activated 40
IDE04300-ENG117587-Vehicle menu operation-menu_display_clock_clamp_15_off not activated 40
IDE04300-ENG117588-Vehicle menu operation-menu_display_clock_over_threshold_high activated 40
IDE04300-ENG117589-Vehicle menu operation-menu_display_clock_standstill not activated 40
IDE04300-ENG117566-Vehicle menu operation-menu_display_compass not activated 40
IDE04300-ENG117570-Vehicle menu operation-menu_display_compass_after_disclaimer not activated 40
IDE04300-ENG117567-Vehicle menu operation-menu_display_compass_clamp_15_off not activated 40
IDE04300-ENG117568-Vehicle menu operation-menu_display_compass_over_threshold_high not activated 40
IDE04300-ENG117569-Vehicle menu operation-menu_display_compass_standstill not activated 40
IDE04300-ENG117656-Vehicle menu operation-menu_display_driving_school not activated 40
IDE04300-ENG117660-Vehicle menu operation-menu_display_driving_school_after_disclaimer not activated 40
IDE04300-ENG117657-Vehicle menu operation-menu_display_driving_school_clamp_15_off not activated 40
IDE04300-ENG117658-Vehicle menu operation-menu_display_driving_school_over_threshold_high not activated 40
IDE04300-ENG117659-Vehicle menu operation-menu_display_driving_school_standstill not activated 40
IDE04300-ENG125034-Vehicle menu operation-menu_display_Ecall not activated 40
IDE04300-ENG125038-Vehicle menu operation-menu_display_Ecall_after_disclaimer not activated 40
IDE04300-ENG126999-Vehicle menu operation-menu_display_eCall_clamp_15_off not activated 40
IDE04300-ENG125036-Vehicle menu operation-menu_display_Ecall_over_threshold_high not activated 40
IDE04300-ENG125037-Vehicle menu operation-menu_display_Ecall_standstill not activated 40
IDE04300-ENG117516-Vehicle menu operation-menu_display_exterior_illumination activated 40
IDE04300-ENG117520-Vehicle menu operation-menu_display_exterior_illumination_after_disclaimer not activated 40
IDE04300-ENG117517-Vehicle menu operation-menu_display_exterior_illumination_clamp_15_off not activated 40
IDE04300-ENG117518-Vehicle menu operation-menu_display_exterior_illumination_over_threshold_high not activated 40
IDE04300-ENG117519-Vehicle menu operation-menu_display_exterior_illumination_standstill not activated 40
IDE04300-ENG117596-Vehicle menu operation-menu_display_headup_display not activated 40
IDE04300-ENG117600-Vehicle menu operation-menu_display_headup_display_after_disclaimer not activated 40
IDE04300-ENG117597-Vehicle menu operation-menu_display_headup_display_clamp_15_off not activated 40
IDE04300-ENG117598-Vehicle menu operation-menu_display_headup_display_over_threshold_high not activated 40
IDE04300-ENG117599-Vehicle menu operation-menu_display_headup_display_standstill not activated 40
IDE04300-ENG117606-Vehicle menu operation-menu_display_hybrid not activated 40
IDE04300-ENG117610-Vehicle menu operation-menu_display_hybrid_after_disclaimer not activated 40
IDE04300-ENG117607-Vehicle menu operation-menu_display_hybrid_clamp_15_off not activated 40
IDE04300-ENG117608-Vehicle menu operation-menu_display_hybrid_over_threshold_high not activated 40
IDE04300-ENG117609-Vehicle menu operation-menu_display_hybrid_standstill not activated 40
IDE04300-ENG117506-Vehicle menu operation-menu_display_Lane_Departure_Warning not activated 40
IDE04300-ENG117510-Vehicle menu operation-menu_display_Lane_Departure_Warning_after_disclaimer not activated 40
IDE04300-ENG117507-Vehicle menu operation-menu_display_Lane_Departure_Warning_clamp_15_off not activated 40
IDE04300-ENG117508-Vehicle menu operation-menu_display_Lane_Departure_Warning_over_threshold_high not activated 40
IDE04300-ENG117509-Vehicle menu operation-menu_display_Lane_Departure_Warning_standstill not activated 40
IDE04300-ENG117631-Vehicle menu operation-menu_display_MFL_jocker activated 40
IDE04300-ENG117635-Vehicle menu operation-menu_display_MFL_jocker_after_disclaimer not activated 40
IDE04300-ENG117632-Vehicle menu operation-menu_display_MFL_jocker_clamp_15_off not activated 40
IDE04300-ENG117633-Vehicle menu operation-menu_display_MFL_jocker_over_threshold_high activated 40
IDE04300-ENG117634-Vehicle menu operation-menu_display_MFL_jocker_standstill not activated 40
IDE04300-ENG117616-Vehicle menu operation-menu_display_night_vision not activated 40
IDE04300-ENG117620-Vehicle menu operation-menu_display_night_vision_after_disclaimer not activated 40
IDE04300-ENG117617-Vehicle menu operation-menu_display_night_vision_clamp_15_off not activated 40
IDE04300-ENG117618-Vehicle menu operation-menu_display_night_vision_over_threshold_high not activated 40
IDE04300-ENG117619-Vehicle menu operation-menu_display_night_vision_standstill not activated 40
IDE04300-ENG117576-Vehicle menu operation-menu_display_oil_level not activated 40
IDE04300-ENG117580-Vehicle menu operation-menu_display_oil_level_after_disclaimer not activated 40
IDE04300-ENG117577-Vehicle menu operation-menu_display_oil_level_clamp_15_off not activated 40
IDE04300-ENG117578-Vehicle menu operation-menu_display_oil_level_over_threshold_high not activated 40
IDE04300-ENG117579-Vehicle menu operation-menu_display_oil_level_standstill not activated 40
IDE04300-ENG117496-Vehicle menu operation-menu_display_pdc not activated 40
IDE04300-ENG117500-Vehicle menu operation-menu_display_pdc_after_disclaimer not activated 40
IDE04300-ENG117497-Vehicle menu operation-menu_display_pdc_clamp_15_off not activated 40
IDE04300-ENG117498-Vehicle menu operation-menu_display_pdc_over_threshold_high not activated 40
IDE04300-ENG117499-Vehicle menu operation-menu_display_pdc_standstill not activated 40
IDE04300-ENG117541-Vehicle menu operation-menu_display_rdk not activated 40
IDE04300-ENG117545-Vehicle menu operation-menu_display_rdk_after_disclaimer not activated 40
IDE04300-ENG117542-Vehicle menu operation-menu_display_rdk_clamp_15_off not activated 40
IDE04300-ENG117543-Vehicle menu operation-menu_display_rdk_over_threshold_high not activated 40
IDE04300-ENG117544-Vehicle menu operation-menu_display_rdk_standstill not activated 40
IDE04300-ENG117626-Vehicle menu operation-menu_display_reversible_belt_pre_load not activated 40
IDE04300-ENG117630-Vehicle menu operation-menu_display_reversible_belt_pre_load_after_disclaimer not activated 40
IDE04300-ENG117627-Vehicle menu operation-menu_display_reversible_belt_pre_load_clamp_15_off not activated 40
IDE04300-ENG117628-Vehicle menu operation-menu_display_reversible_belt_pre_load_over_threshold_high not activated 40
IDE04300-ENG117629-Vehicle menu operation-menu_display_reversible_belt_pre_load_standstill not activated 40
IDE04300-ENG117636-Vehicle menu operation-menu_display_road_sign_identification not activated 40
IDE04300-ENG117640-Vehicle menu operation-menu_display_road_sign_identification_after_disclaimer not activated 40
IDE04300-ENG117637-Vehicle menu operation-menu_display_road_sign_identification_clamp_15_off not activated 40
IDE04300-ENG117638-Vehicle menu operation-menu_display_road_sign_identification_over_threshold_high not activated 40
IDE04300-ENG117639-Vehicle menu operation-menu_display_road_sign_identification_standstill not activated 40
IDE04300-ENG117556-Vehicle menu operation-menu_display_seat_configuration not activated 40
IDE04300-ENG117560-Vehicle menu operation-menu_display_seat_configuration_after_disclaimer not activated 40
IDE04300-ENG117557-Vehicle menu operation-menu_display_seat_configuration_clamp_15_off not activated 40
IDE04300-ENG117558-Vehicle menu operation-menu_display_seat_configuration_over_threshold_high not activated 40
IDE04300-ENG117559-Vehicle menu operation-menu_display_seat_configuration_standstill not activated 40
IDE04300-ENG117551-Vehicle menu operation-menu_display_sia activated 40
IDE04300-ENG117555-Vehicle menu operation-menu_display_sia_after_disclaimer not activated 40
IDE04300-ENG117552-Vehicle menu operation-menu_display_sia_clamp_15_off not activated 40
IDE04300-ENG117553-Vehicle menu operation-menu_display_sia_over_threshold_high activated 40
IDE04300-ENG117554-Vehicle menu operation-menu_display_sia_standstill not activated 40
IDE04300-ENG117511-Vehicle menu operation-menu_display_side_assistant not activated 40
IDE04300-ENG117515-Vehicle menu operation-menu_display_side_assistant_after_disclaimer not activated 40
IDE04300-ENG117512-Vehicle menu operation-menu_display_side_assistant_clamp_15_off not activated 40
IDE04300-ENG117513-Vehicle menu operation-menu_display_side_assistant_over_threshold_high not activated 40
IDE04300-ENG117514-Vehicle menu operation-menu_display_side_assistant_standstill not activated 40
IDE04300-ENG117621-Vehicle menu operation-menu_display_side_view not activated 40
IDE04300-ENG117625-Vehicle menu operation-menu_display_side_view_after_disclaimer not activated 40
IDE04300-ENG117622-Vehicle menu operation-menu_display_side_view_clamp_15_off not activated 40
IDE04300-ENG117623-Vehicle menu operation-menu_display_side_view_over_threshold_high not activated 40
IDE04300-ENG117624-Vehicle menu operation-menu_display_side_view_standstill not activated 40
IDE04300-ENG117676-Vehicle menu operation-menu_display_Start_Stop_reasons not activated 40
IDE04300-ENG117680-Vehicle menu operation-menu_display_Start_Stop_reasons_after_disclaimer not activated 40
IDE04300-ENG117677-Vehicle menu operation-menu_display_Start_Stop_reasons_clamp_15_off not activated 40
IDE04300-ENG117678-Vehicle menu operation-menu_display_Start_Stop_reasons_over_threshold_high not activated 40
IDE04300-ENG117679-Vehicle menu operation-menu_display_Start_Stop_reasons_standstill not activated 40
IDE04300-ENG117611-Vehicle menu operation-menu_display_ugdo not activated 40
IDE04300-ENG117615-Vehicle menu operation-menu_display_ugdo_after_disclaimer not activated 40
IDE04300-ENG117612-Vehicle menu operation-menu_display_ugdo_clamp_15_off not activated 40
IDE04300-ENG117613-Vehicle menu operation-menu_display_ugdo_over_threshold_high not activated 40
IDE04300-ENG117614-Vehicle menu operation-menu_display_ugdo_standstill not activated 40
IDE04300-ENG117581-Vehicle menu operation-menu_display_vin activated 40
IDE04300-ENG117585-Vehicle menu operation-menu_display_vin_after_disclaimer not activated 40
IDE04300-ENG117582-Vehicle menu operation-menu_display_vin_clamp_15_off not activated 40
IDE04300-ENG117583-Vehicle menu operation-menu_display_vin_over_threshold_high activated 40
IDE04300-ENG117584-Vehicle menu operation-menu_display_vin_standstill not activated 40
IDE04300-ENG117661-Vehicle menu operation-menu_display_weariness_recognition activated 40
IDE04300-ENG117665-Vehicle menu operation-menu_display_weariness_recognition_after_disclaimer not activated 40
IDE04300-ENG117662-Vehicle menu operation-menu_display_weariness_recognition_clamp_15_off not activated 40
IDE04300-ENG117663-Vehicle menu operation-menu_display_weariness_recognition_over_threshold_high activated 40
IDE04300-ENG117664-Vehicle menu operation-menu_display_weariness_recognition_standstill not activated 40
IDE04300-ENG117521-Vehicle menu operation-menu_display_windows not activated 40
IDE04300-ENG117525-Vehicle menu operation-menu_display_windows_after_disclaimer not activated 40
IDE04300-ENG117522-Vehicle menu operation-menu_display_windows_clamp_15_off not activated 40
IDE04300-ENG117523-Vehicle menu operation-menu_display_windows_over_threshold_high not activated 40
IDE04300-ENG117524-Vehicle menu operation-menu_display_windows_standstill not activated 40
IDE04300-ENG117546-Vehicle menu operation-menu_display_wiper not activated 40
IDE04300-ENG117550-Vehicle menu operation-menu_display_wiper_after_disclaimer not activated 40
IDE04300-ENG117547-Vehicle menu operation-menu_display_wiper_clamp_15_off not activated 40
IDE04300-ENG117548-Vehicle menu operation-menu_display_wiper_over_threshold_high not activated 40
IDE04300-ENG117549-Vehicle menu operation-menu_display_wiper_standstill not activated 40
IDE04307-ENG117700-Vehicle function list BAP-ACC_0x05 not activated 53
IDE04307-ENG117701-Vehicle function list BAP-ACC_0x05_msg_bus Comfort data bus 53
IDE04307-ENG117702-Vehicle function list BAP-air_suspension_0x06 not activated 53
IDE04307-ENG117703-Vehicle function list BAP-air_suspension_0x06_msg_bus Comfort data bus 53
IDE04307-ENG117764-Vehicle function list BAP-Amplifier_0x2D not activated 53
IDE04307-ENG117765-Vehicle function list BAP-Amplifier_0x2D_msg_bus Comfort data bus 53
IDE04307-ENG117696-Vehicle function list BAP-auxilary_heating_0x03 not activated 53
IDE04307-ENG117697-Vehicle function list BAP-auxilary_heating_0x03_msg_bus Comfort data bus 53
IDE04307-ENG117744-Vehicle function list BAP-AWV_0x1B not activated 53
IDE04307-ENG117745-Vehicle function list BAP-AWV_0x1B_msg_bus Comfort data bus 53
IDE04307-ENG117758-Vehicle function list BAP-BCmE_0x23 not activated 53
IDE04307-ENG117759-Vehicle function list BAP-BCmE_0x23_msg_bus Comfort data bus 53
IDE04307-ENG117760-Vehicle function list BAP-Brake_0x26 not activated 53
IDE04307-ENG117761-Vehicle function list BAP-Brake_0x26_msg_bus Comfort data bus 53
IDE04307-ENG117717-Vehicle function list BAP-central_locking_0x0D activated 53
IDE04307-ENG117716-Vehicle function list BAP-central_locking_0x0D_msg_bus Comfort data bus 53
IDE04307-ENG117736-Vehicle function list BAP-charisma_0x17 not activated 53
IDE04307-ENG117737-Vehicle function list BAP-charisma_0x17_msg_bus Comfort data bus 53
IDE04307-ENG117734-Vehicle function list BAP-clima_slave_2_0x16 not activated 53
IDE04307-ENG117735-Vehicle function list BAP-clima_slave_2_0x16_msg_bus Comfort data bus 53
IDE04307-ENG117692-Vehicle function list BAP-climatic_master_0x01 activated 53
IDE04307-ENG117693-Vehicle function list BAP-climatic_master_0x01_msg_bus Comfort data bus 53
IDE04307-ENG117694-Vehicle function list BAP-climatic_slave_0x02 not activated 53
IDE04307-ENG117695-Vehicle function list BAP-climatic_slave_0x02_msg_bus Comfort data bus 53
IDE04307-ENG117724-Vehicle function list BAP-clock_0x11 activated 53
IDE04307-ENG117725-Vehicle function list BAP-clock_0x11_msg_bus Comfort data bus 53
IDE04307-ENG117732-Vehicle function list BAP-compass_0x15 not activated 53
IDE04307-ENG117733-Vehicle function list BAP-compass_0x15_msg_bus Comfort data bus 53
IDE04307-ENG117722-Vehicle function list BAP-driver_seat_0x10 not activated 53
IDE04307-ENG117723-Vehicle function list BAP-driver_seat_0x10_msg_bus Comfort data bus 53
IDE04307-ENG125039-Vehicle function list BAP-Ecall_0x33 not activated 53
IDE04307-ENG125040-Vehicle function list BAP-Ecall_msg_bus_0x33 Comfort data bus 53
IDE04307-ENG117708-Vehicle function list BAP-exterieur_light_0x09 activated 53
IDE04307-ENG117709-Vehicle function list BAP-exterieur_light_0x09_msg_bus Comfort data bus 53
IDE04307-ENG117698-Vehicle function list BAP-headup_displ_0x04 not activated 53
IDE04307-ENG117699-Vehicle function list BAP-headup_displ_0x04_msg_bus Comfort data bus 53
IDE04307-ENG117746-Vehicle function list BAP-Hybrid_0x1D not activated 53
IDE04307-ENG117747-Vehicle function list BAP-Hybrid_0x1D_msg_bus Comfort data bus 53
IDE04307-ENG117706-Vehicle function list BAP-interieur_light_0x08 activated 53
IDE04307-ENG117707-Vehicle function list BAP-interieur_light_0x08_msg_bus Comfort data bus 53
IDE04307-ENG117740-Vehicle function list BAP-LDW_HCA_0x19 not activated 53
IDE04307-ENG117741-Vehicle function list BAP-LDW_HCA_0x19_msg_bus Comfort data bus 53
IDE04307-ENG117720-Vehicle function list BAP-MFA_0x0F activated 53
IDE04307-ENG117721-Vehicle function list BAP-MFA_0x0F_msg_bus Comfort data bus 53
IDE04307-ENG117767-Vehicle function list BAP-MFL_Jocker_0x34 activated 53
IDE04307-ENG117766-Vehicle function list BAP-MFL_Jocker_msg_bus_0x34 Databus Infotainment 53
IDE04307-ENG117719-Vehicle function list BAP-mirror_0x0E not activated 53
IDE04307-ENG117718-Vehicle function list BAP-mirror_0x0E_msg_bus Comfort data bus 53
IDE04307-ENG117738-Vehicle function list BAP-Night_Vision_0x18 not activated 53
IDE04307-ENG117739-Vehicle function list BAP-Night_Vision_0x18_msg_bus Comfort data bus 53
IDE04307-ENG117710-Vehicle function list BAP-parking_assist_0x0A not activated 53
IDE04307-ENG117711-Vehicle function list BAP-parking_assist_0x0A_msg_bus Not available 53
IDE04307-ENG117752-Vehicle function list BAP-Passenger_Seat_0x20 not activated 53
IDE04307-ENG117753-Vehicle function list BAP-Passenger_Seat_0x20_msg_bus Comfort data bus 53
IDE04307-ENG117750-Vehicle function list BAP-Reversible_Seat_Belt_Tightener_0x1F not activated 53
IDE04307-ENG117751-Vehicle function list BAP-Reversible_Seat_Belt_Tightener_0x1F_msg_bus Comfort data bus 53
IDE04307-ENG117726-Vehicle function list BAP-service_interval_display_0x12 activated 53
IDE04307-ENG117727-Vehicle function list BAP-service_interval_display_0x12_msg_bus Comfort data bus 53
IDE04307-ENG117748-Vehicle function list BAP-SideView_0x1E not activated 53
IDE04307-ENG117749-Vehicle function list BAP-SideView_0x1E_msg_bus Comfort data bus 53
IDE04307-ENG117762-Vehicle function list BAP-Start_Stop_reasons_0x27 not activated 53
IDE04307-ENG117763-Vehicle function list BAP-Start_Stop_reasons_0x27_msg_bus Comfort data bus 53
IDE04307-ENG117742-Vehicle function list BAP-SWA_0x1A not activated 53
IDE04307-ENG117743-Vehicle function list BAP-SWA_0x1A_msg_bus Comfort data bus 53
IDE04307-ENG117704-Vehicle function list BAP-tire_pressure_system_0x07 not activated 53
IDE04307-ENG117705-Vehicle function list BAP-tire_pressure_system_0x07_msg_bus Comfort data bus 53
IDE04307-ENG117754-Vehicle function list BAP-traffic_sign_recognition_0x21 not activated 53
IDE04307-ENG117755-Vehicle function list BAP-traffic_sign_recognition_0x21_msg_bus Comfort data bus 53
IDE04307-ENG117730-Vehicle function list BAP-UGDO_0x14 not activated 53
IDE04307-ENG117731-Vehicle function list BAP-UGDO_0x14_msg_bus Comfort data bus 53
IDE04307-ENG117728-Vehicle function list BAP-unit_master_0x13 activated 53
IDE04307-ENG117729-Vehicle function list BAP-unit_master_0x13_msg_bus Comfort data bus 53
IDE04307-ENG117712-Vehicle function list BAP-VPS_0x0B activated 53
IDE04307-ENG117713-Vehicle function list BAP-VPS_0x0B_msg_bus Comfort data bus 53
IDE04307-ENG117756-Vehicle function list BAP-weariness_rcognition_0x22 activated 53
IDE04307-ENG117757-Vehicle function list BAP-weariness_rcognition_0x22_msg_bus Databus Infotainment 53
IDE04307-ENG117714-Vehicle function list BAP-wiper_comfort_0x0C not activated 53
IDE04307-ENG117715-Vehicle function list BAP-wiper_comfort_0x0C_msg_bus Comfort data bus 53
IDE04330-Transfer of release code for a SWaP function 0 1
IDE04331-Selection of release codes for a SWaP function FF FF FF FF 4
IDE04521-Sporadic ring break detection Visual 1
IDE04522-Awakening ability on optical databus OFF 1
IDE04550-Bluetooth: Sniff mode OFF 1
IDE05112-MAS02228-Image position-X coordinate 0 2
IDE05112-MAS02229-Image position-Y coordinate 0 2
IDE05113-Infotainment Recorder activated 1
IDE06698-MAS00839-Audio management input gain-TV Tuner -128 dB 6
IDE06698-MAS00846-Audio management input gain-Satellite radio -128 dB 6
IDE06698-MAS01984-Audio management input gain-Radio (FM) -128 dB 6
IDE06698-MAS01985-Audio management input gain-Radio (AM) -128 dB 6
IDE06698-MAS01986-Audio management input gain-Digital radio (DAB) -128 dB 6
MAS00951-Bluetooth On 1
MAS01968-Fan normal 1
MAS02809-MAS02870-Check tone frequency-High note frequency range 4000 Hz 6
MAS02809-MAS02871-Check tone frequency-Medium note frequency range 1000 Hz 6
MAS02809-MAS02872-Check tone frequency-Low note frequency range 100 Hz 6
ENG117917-BAP_Debug_Mode_Release not_released 1
ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_Unit-X1 0 6
ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2 50 6
ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3 100 6
ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_Unit-Y1 0 6
ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2 50 6
ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3 100 6
ENG117914-ENG101574-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X1 0 6
ENG117914-ENG99557-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X2 50 6
ENG117914-ENG102140-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X3 100 6
ENG117914-ENG99777-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y1 0 6
ENG117914-ENG100480-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y2 50 6
ENG117914-ENG100773-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y3 100 6
ENG117915-ENG101574-Dimming_Functional_Illumination_for_Operating_Unit-X1 0 12
ENG117915-ENG99557-Dimming_Functional_Illumination_for_Operating_Unit-X2 10 12
ENG117915-ENG102140-Dimming_Functional_Illumination_for_Operating_Unit-X3 100 12
ENG117915-ENG102936-Dimming_Functional_Illumination_for_Operating_Unit-X4 150 12
ENG117915-ENG103548-Dimming_Functional_Illumination_for_Operating_Unit-X5 220 12
ENG117915-ENG113992-Dimming_Functional_Illumination_for_Operating_Unit-X6 253 12
ENG117915-ENG99777-Dimming_Functional_Illumination_for_Operating_Unit-Y1 0% 12
ENG117915-ENG100480-Dimming_Functional_Illumination_for_Operating_Unit-Y2 6% 12
ENG117915-ENG100773-Dimming_Functional_Illumination_for_Operating_Unit-Y3 16% 12
ENG117915-ENG100631-Dimming_Functional_Illumination_for_Operating_Unit-Y4 30% 12
ENG117915-ENG102174-Dimming_Functional_Illumination_for_Operating_Unit-Y5 60% 12
ENG117915-ENG113993-Dimming_Functional_Illumination_for_Operating_Unit-Y6 100% 12
ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1 0 12
ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2 10 12
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3 50 12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4 100 12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5 150 12
ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6 253 12
ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1 1% 12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2 2% 12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3 4% 12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4 11% 12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5 30% 12
ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6 100% 12
ENG117809-p_damping_Display 5 ms 1
ENG117808-p_HMI_Display 10% 1
ENG117906-Shift_Remote_Test_Volume Default 1
Elapsed Time: 00:26
Okay, so after doing some tests I’ve found something interesting.
When I put the car into reverse and then reset the MMI, while the MMI is booting up it shows the reverse image for a few seconds and then disappear once it boots up.
That’s why I’m 200% sure the problem is in 5F.
I did my retrofit around 2 weeks and all working fine with the coding below on my 2017 facelift S3:
1.
Register the 6C module in the gateway
2.
if you have installed parking assistance system
please code " 10 " . tick rear camera installed .
3. Module 6C code :
02 73 01 01 02 00 20 01 40 00 40
I didn't need to do this as my camera worked. My 6C module coding is different to the coding stated above
4.
Finally you have to enter the Module 5F
Adaptation
Search for
Car_Funktion_List_BAP_Gen2_VPS_0x0B Switch to activated
Car_Funktion_List_BAP_Gen2_VPS_0x0B_msg_bus dial terminal 15
It might be worth contacting the seller of the retrofit kit to get the coding off them. I didn't need to reset the MMI after coding.
1.
2.
3. Module 6C code :
4.
Adaptation
Search for
Yes, that’s exactly what I have as well except mine is Databus Comfort for the VPS message bus and not terminal 15 (tried that one as well).
You have facelift so I assume they’re less prone to errors.
Yes I have the tech pack advanced so probably have different modules/module configuration to you. Sorry I can't help more :frown:
Thank you anyway. I’ll wait for a more professional coding aspect from someone like @DJAlix.
Hello Fraysa
I have the same issue, do you resolved?
I installed in a Audi A4 2017 sline original back up camera and the procedure is The same 6C and 5F conf.
I can see the 6C working detect the Reverse input, movement of the steering wheel but the display don´t change
I don´t know what more do. as you I think is something related with the 5F
Please hep
1.
2.
3. Module 6C code :
4.
Adaptation
Search for
Where did you get all retrofit kit from buddy?
Hello Fraysa
Please hep
Where did you install the CAN connections?
Reactions: dantdi
Hello
in to the gateway under the rear seat, 12 can high (Orange purple) and 30 can low (Orange brown)
I can see the 6C live now after the connection in ODIS, if I change to reverse I can see the change in the 6C, the problem is the display no change
Thanks in advance for your help
1 Fault Found:
B2010 00 [009] - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 78
Mileage: 109384 km
Date: 2019.06.24
Time: 23:01:14
passive
Elapsed Time: 00:26
If the camera is new, it will need Parameterisation with VCP
Hello
Wanted to make sure as this is the a3 forum and the a4 connects differently.
What error messages are you getting? Please post a scan.
media:
might also be an idea to let us know what coding steps you have taken.
media:
Yes I see the process in the same as the A4
After connection the video in the cuadlock in the mmi 6 and 12, connect the Canbus cables to the gateway, then
enter the Module 5F
Adaptation
Search for
The module 6c looks working because in the measurements I put reverse and detected I move the steering wheel and change values, and no error or issues detected by the Odis sacan tool
But the display Don't change to show the image , do nothing
enter the Module 5F
Adaptation
Search for
You need to long code control module 09 also
off the top of my head no but if you look at the long coding you just need to activate the bit / select the drop down for reversing camera.
Thanks , I already ordered my VCDS, I going to wait until then to test, my mechanic with the software is too far from here
Thanks and let you know if works
Regards
Reactions: DJAlix
https://www.aliexpress.com/item/32863217665.html?spm=2114.12010612.8148356.48.4db77697YWHjr3
Even though it shows the OEM display with the translucent blue box on the video image, mine came with an aftermarket camera so it has coloured lines instead (which I prefer because it's difficult to see what's under the blue box). It all works as it would from the factory and mine has a trailer mode/birds eye view too
If I can take some of your time , do you recommend this camera? What’s your experience with it ? Is it a good oem alternative are all the “modes “ available? Even in dark light? Sorry for all the questions but I am in doubt.
It works as OEM and I haven't had any issues with it. I've attached an image of how it displays. Works well in low light conditions too
IMG 7236 IMG 7239
How much are people paying for the reverse camera to be supplied and fitted i have wanted to get this done for ages but never got round to it .
Regards
Fixed
The issue was the 6C configuration
If is not setup in base of you model equipment is not do nothing and your display don't show the camera
For me was to change to only rear parking sensor and works , this are the instructions if someone else need it
Changes are made in ADDRESS 6C "rear view camera".
- Connect address 6C "Rear view camera"
- Select coding
Code this controller as described in your VCP / VCDSdiagnostic system, depending on vehicle equipment.
We deliver this control unit already pre-parameterized as well as pre-coded.
Complete this already existing "standard coding" with the respective vehicle equipment.
Example codes:
Byte 04 - Bit 0 blocked to 1 = AHK
Byte 04 - Bit 1 to 1 = Parking aid front + rear installed
Byte 04 - Bit 1 to 0 = Rear parking aid installed
Byte 04 - Bit 2 to 1 = Parking Assist installed
Byte 07 - Bit 0 to 1 = Guides across
Byte 07 - Bit 1 to 1 = Guides parallel
Byte 07 - Bit 2 on 1 = Guides Trailer
Byte 07 - Bit 3 on 1 = Guides cross
Byte 07 - Bit 4 on 1 = Guides park steering assist installed
Thanks for your support
Regads
20200711 164422
Reactions: Peter Peter
Hi my friend i have the same problem....did you find any solution?
That tends to mean that the coding is incorrect. That also happened to me, in my case it was because I had OPS enabled in the parking module (10 Park/Assist) when I did not have it installed in the car (a few months prior I tried to enable OPS with only having rear sensors installed which is not possible in FL models and then forgot to turn it back off - leaving it on did not have any effect at the time but then messed up with my rear camera when I had it installed a few months later).
Coding should be:
1.Register the 6C module in the gateway
2.if you have installed parking assistance system, go to "10 Park/Assist" - tick rear camera installed.
3. Module 6C
4.Finally you have to enter the Module 5F
Adaptation
Car_Funktion_List_BAP_Gen2_VPS_0x0B = activated
Car_Funktion_List_BAP_Gen2_VPS_0x0B_msg_bus = terminal 15
Reactions: henkkeumus
Coding should be:
3. Module 6C
Adaptation
Firts of all thanks for your reply ! My camera is from Ali express (check photo) and its supposed to be plug and play...from feed back I found 2-3 clients that the have successfully install it in same car like mine (Audi A4 b9 2016') now I'm waiting to receive my obd11 so i can try you coding advice...also my rear parking sensors are after market ....
Screenshot 20220208 114633 comalibabaaliexpresshd edit 309511376828812
Yes, but your headunit needs to know what to do with the signals it's getting.. You will need to let it know it can expect a videosignal on PIN (x) when you put your car in reverse etc.. So you need to code the thing. Just like everything else you retrofit, modules need to know the hardware is there before you can start using it.
Reactions: maniasg
Coding should be:
3. Module 6C
Adaptation
So just receive my obdeleven pro and I'm trying ....but how i register 6c ???
" 1.Register the 6C module in the gateway"
Sorry newbie here....
So i following Bogdans guide but i have those errors and 6C module is black and i cant change anything in it...
Step by step:
Select 19 Gateway
Select Adaptation
Select Installation list, specified installations
Search „camera” in the list and check Coded and then Slide to write
Select 09 Central Electrics
Select Long Coding (Attention! Do a full backup of your current long coding number before any new long coding)
Check the icon with „01010101” on the top right corner, select Byte Index and enter value 35
On Byte 35 check Bit 4 and then Slide to write
Select 5F Multimedia
Select Adaptation
Search for „Gen2” and select Car function List BAP Gen2
Search for „VPS„, activate VPS 0x0B and on VPS 0x0B msg bus select Terminal 15
Slide to write
Then try to register 6C to gateway but i have communication problems so I can't edit 6C is black not green like everything else....
Coding should be:
3. Module 6C
Adaptation
Just fitted my cam. Got instructions from seller who didnt even worked. This worked for me flawlessy! Thanks mate!!!!
How did you register 6C ? Obdeleven or ?
I'm using VCDS mate.
I see you have no communication with the 6C module. Then the CAN Hi and CAN Lo are not connected properly. Can you check that?
The grey connector in the quadlock connector, PIN 6 and 12 are they occupied? And if so, do they run to the camera or only to the "original quadlock" because then that is only used for your headunit.
The camera you bought is not a highline one, I think this taps into the system on a NON-OEM manner(?). Normally there should be 2 orange wires running from the camera to your CAN wires to enable communication between the module and the car mate.
Reactions: Potterswheel
Its this camera supposed to be plug and play ...just one cable
  • Screenshot_20220220_194931_com.alibaba.aliexpresshd_edit_932040338381738.jpg
I just had a look at the ad on Ali (https://nl.aliexpress.com/item/4000...1;51.11;-1;-1@salePrice;EUR;search-mainSearch)
If you read the description there is alot of cars from your year who are not compatible. It's a bit weirdly translated from Chinese into English but I would reckon to contact the seller and ask if he can help you out.
The normal way is that the camera needs to be registered to the car in the CAN-GW like you did. Then when you click on the 6C module it will communicate with camera over the CAN Hi and CAN Lo signal wires. Those are the twisted orange wires into the 12 pins grey connector block in the quadlock connector that goes into the unit.
As far as I can see there is only 1 cable going to the camera, thats the cable with the purple connectors. How many PINS does that connector have? It needs atleast 6 pins otherwise you are missing out on some...
- 12V power PIN
- GND pin
- CAN high
- CAN low
- Videofeed IN
- Videofeed
If that does not have atleast 6 pins then I'm not sure how this will even work on an OEM MIB unit...
I just had a look at the ad on Ali (https://nl.aliexpress.com/item/4000230897829.html?spm=a2g0o.productlist.0.0.2b797c2f4EWdRg&algo_pvid=8c4a2c04-385e-4ac6-bd4e-72b6820ea73a&algo_exp_id=8c4a2c04-385e-4ac6-bd4e-72b6820ea73a-0&pdp_ext_f={"sku_id":"12000021316842790"}&pdp_pi=-1;51.11;-1;-1@salePrice;EUR;search-mainSearch)
- 12V power PIN
- GND pin
- CAN high
- CAN low
- Videofeed IN
- Videofeed
Also a lot that they say that fits.... anyway yes purple wire has 6 pins...today i have noticed that camera also works for 10 seconds when i start the car and select R....its working during mmi boots or reset but when mmi finally open camera stop working
Im afraid that it doesn't work because i dont have rear parking sensors...
I contacted with seller he send those photos....i read somewhere else that maybe CAN-high & CAN -low wires have to be reversed thats why 6C module cant be registered... I'll try it later on....
red: power,
black: ground,
yellow: video+
green and white canbus hi/low
  • Screenshot_20220222_114104_com.alibaba.aliexpresshd_edit_1032690877957005.jpg
  • Screenshot_20220222_114131_com.android.gallery3d_edit_1032721926920542.jpg
Well that is has 6pins is a good thing tough.. if you cant enter the 6C module then its a communication error (if you sure that it has proper 12V and GND). This comed down to your canbus connection. Are you able to do any continuity test on the wires?
Verzonden vanaf mijn iPhone met Tapatalk
