Hi, had a bit of drama with the car lately, faults are now pointing to a fuel pump gone, which im going to try tomoro,
regardless iv had it plugged in and have these fault codes
12597 - intake manifold control lower stop not reached p3135 upper limit reached
04120 - intake manifold runner (bank 2) lower limit not reached p1018 upper limit reached - intermittent
05676 - glow plug control module supply voltage open curcuit on load side p162c
its an 05 audi a4 3.0 quattro bkn engine
bit of background i had the ecu box with water in it causing dramas, changed the relays out but battery got knackered in the process, got a new battery now will fit tomoro but while trying to jump start it, it would crank but not fire, are these issues related or are these seperate issues that also need attention
thanks in advance
thanks in advance
