Are you able to connect to the RLHS? Am asking because 1) you have changed the coding but 2) you have communication errors.
I think I know what the issue might be but just want to confirm the above.
@DJAlix
With the RLHS you mean the sensor?
Yes i can connect it and change code's
I bought a cable set from K-electronic in germany
with this there was a manual
From ebay i bought the first sensor the 8UD model
Than to a VCDS specialist for coding, in the manual they say it need to be 02005D, so he did, but nothing...
Second he try to add manual the line's (also told in the manual) than the code change into 0A006C
But stil fault codes so i try to find out and found this forum.
Here i read and find out we had the wrong sensor 8UD most be a 8U0 so the second i bought was a 8U0955559 model and it say this would fit into my car (see my post before) but you say no it most be a B-B and not a C-B model.
So the 3de came, and from that one you get the code list.
But i think also the light switch is not okay, because i have now a Q model and i think i need the AJ model.
Because the front FOG lights still not working also and the VCDS specialis here told me if you have the sensor correct working the switch also is correct working....but still not
So tell me what to do now, because i have the coding tool to now
