Gearbox Woes
cakeoma
Scotland
I have an A3 Black Edition, Quattro, 180 Tdi registered 1/9/2017. Mileage 22K, bought as a demonstator.
I recently had all tyres and brakes renewed at my local garage ( not a main dealer ) and when I collected the car the main man told me there was a small leak on the gearbox.
I booked in for further investigation and when I went to collect the car he gave me some very bad news. The core plugs or shaft end covers had rusted where there were stone chips and were leaking slightly, he'd been in touch with his Audi parts supplier who had told him these parts were part of the gearbox casing and not available to replace seperately. In other words it was a new gearbox job !!! These covers are visible looking into the front nearside wheel arch with the wheel on full lock. They measure 85mm and have a small dome around 35mm in the middle. I've found non-Audi ones at 85mm but they're just flat across their width.
Removing the existing ones will destroy them so if I haven't got genuine parts for replacement and the others won't fit I'm really stuffed.
My main man ( who's an ex-Audi mechanic in whom I have complete confidence ) suggested taking the car to my dealer and trying for a good will repair. However the car is 7-8 months out of warranty now and should I be turned down I then have a marked car on the Audi system which would affect trade in value.
There's no way I'm spending £10k pounds on a new gearbox so it looks like a new car before long. I find it hard to believe that I'm in this situation when the parts to sort the problem would only be £100 tops for the pair.
I've just joined this forum for this post as I know there is a lot of knowledge in places like this and there's always a chance someone might be able to help.
Cheers, Alan
Any pics of the affected parts on your car.
Surely and independent gearbox specialist/rebuilder could help ?
Seems a shame to have to move a car on with such a nice spec for the sale of some core plugs.
I am sure if you whipped the gearbox out a good machine shop could machine threads on them and plug them. I would even consider welding something over them.
Got to be a better option.
Reactions: Sibmets
Probably needs moving to the 8V forum this if it's a 17 plate.
obviously much more information is required , gearbox type and gearbox code , the plugs are indeed a one time seal , however they are readily available from main dealer , the 02m and 02q uses 79mm and 84mm items, note must be taken that there will be a shim behind these seals that gives the bearings end float so care taken to put shims back in ......
Reactions: NHN
As above, there are some available, but box code is needed at minimum.
Thanks, I'll have a go myself with a main dealer.
Hi, here they are ! Not sure what services you offer but I'm a long way from anywhere, about 4.5 hours north of Glasgow. I've contacted a main dealer myself so let's see what happens. I can't believe I'm the first to suffer with this, the window in the wheel arch seems designed to allow stones to chip
IMG 6185 3
IMG 6184 2
these plugs !
9
539
543
4K
