When the fec is changed , where do you download the maps?
Verzonden vanaf mijn iPhone met Tapatalk
Here: http://map.audi-mib.ru/When the fec is changed , where do you download the maps?
hey did you figure this out?Hi @georgi0 - yeah no issues with the patches - turns out I needed a different FEC code for RoW maps which is 023D00ee instead of 023000ee. There are two files to change this in within the patches folder for MIB.
Next part that I am stuck on though is that you can't apply the FEC patch on non-stock firmware (as i've already flashed the EU FECs).. there is a note that you can go back to stock FW by applying update via user defines SWDL.
Any thoughts on how to do this? I can see user defined update in the advanced options which I can check on but then not sure of the next step(s) - do I need to reinstall FW from the Red engineering menu by selecting user defined update and checking everything to Yes?
thanks
JL
Can you provide instructions on how to update the radio DB/gracenote please?Mib software link
user guest
Pass guest
You have to update the maps via downloading them.
TMC pro still works.
I've installed 2023 maps. All perfect.
Ive also updated the radio database to show more radio station art and Gracenote for more album art cover
Radio station logos cant be updated as far as i knowIf anyone has instructions on how to update the radio station logos and gracenote on my 2017 A4 I'd be grateful!
Yes they can via the MIB software The file is in mbq solution/radiostIonDB/vw_stl_db_euRadio station logos cant be updated as far as i know
Hey!! I just wanted to check if this will also work on my TTS 2016. It still have the maps from 2015/2016. Don’t know which one it would be MIB1 or MIB2, still trying to figure that out.Are these maps to download somewhere? I've looked everywhere on forums, newsgroups and torrents but I can't seem to find maps for my MIB2 FL 2017 A3.
Thanks. I’ll go with that then. The file size on the website linked by Boo-boo is 26.2Gb, so I wondered if 32Gb would be adequate64GB SD is recommended
I can see the link for 2023/2024 maps but not 2019 :-(On the download link on the above site
Yeah, I need up update the fec first. mate. seemed to have missed that bit. SorryYour car should update via the MMi to the latest it'll allow using the fec code you have installed. Unless yours uses a disc
Ok guys, I got it figured. You will have to be prepared to "hack" your unit with custom firmware to run on your MIB unit. Well, it's not even that, it's firmware running from an SD-card and installing a bootloader into the unit enabling you to run custom scripts on your unit.
Next to the map update it also enables CarPlay, Google Auto and Video in Motion + unlocks lifetime maps (so you can just download maps and update the database of your current model). So yes, it's true that the MIB is "licensed" normally but this patch will make the unit think it has lifetime maps updates and will hapily accept any map update you feed it year after year .
Download: https://mibsolution.one/?module=fileman§ion=do&page=download&paths[]=/ROOT/1/18/M.I.B_3.1.6_20220120.7z
This will download a tool M.I.B. (More Incredible Bash). Get yourself an SD card and extract the content of the 7zip folder to your FAT32 formatted SD-card.
When done so put the SD-card in SD-slot 1 (important), do not put it in slot 2 but in slot 1!
Note: Start your car or make sure it's on power leads to charge battery while updating. If you stop or turn down the power in the middle of an update you'll brick your unit and render it useless.
This tutorial looks a bit sketchy and I was sceptical as first aswell but took the leap of faith in the amazing community it has behind this project and it's the best leap I've ever took .
1. Open the REM (Red Engineering Menu) by holding the NAV + MEDIA buttons for aprox 10 seconds.
2. Hit 'update'
3. Hit 'standard'
4. Scroll down and hit 'Start update'.
- This will write a bootloader to your MIB2 unit, it does not interfere with your current Audi firmware. Just let is update as usual. The unit will reboot 3 times during the process.
5. When the car is started up again hold the buttons NAV + RADIO to open the GEM (Green Engineering Menu)
6. Hit "M.I.B"
7. Scroll down untill you see the option to create a backup. For the sake of backups please create one, there is a great community behind this tool that will help you get back on track if you systems crashed or is not functionalling well. But then they will need logs and a backup ofcourse.
Note again. DO NOT, I REPEAT. DO NOT STOP THE UPDATE UNTILL IS SAYS ITS FINISHED. You can scroll down to check up on it's status. Again, NEVER turn off the power during an update. This will brick the device and render it useless, this is not recoverable.
8. When done you can hit the back button to go back to the 'main menu'.
9. To activate CarPlay, Google Auto and Video in Motion hit the option 'patch_ifs_root_aio'
10. Hit the option 'Flash_patched_image |add FECs | CP/AA coding'
11. Let the update run, again do NOT turn anything off untill its completely done.
12. After the update the system will reboot and CarPlay will be active on your system.
13. This update also enables the FEC code for lifetime Map updates. Download the maps in the opening post of this topic and put it on your SD-card.
14. Now go through the normal update procedure through the main menu and your MIB unit will accept the new maps and you can enjoy new maps every year they come out.
Note: The GEM menu will be available untill Audi or you renew/update the firmware on the MIB unit.
Hope I can help you guys out with this, if you have any doubts or difficulties PM me I'm happy to help out.
Hi Booboo, I need to patch my FEC as the code is from 2020 and then install new maps. Can you please help me? I'm on MHIQ2_ER_AUG22_P4170 - MU 1117 - Current FEC is 02300024Your car should update via the MMi to the latest it'll allow using the fec code you have installed. Unless yours uses a disc
Does it make any difference if was to use microSD card with an adaptor? if was to have go at this, genuinely don't know if makes difference.64GB SD is recommended
Henk,Ok guys, I got it figured. You will have to be prepared to "hack" your unit with custom firmware to run on your MIB unit. Well, it's not even that, it's firmware running from an SD-card and installing a bootloader into the unit enabling you to run custom scripts on your unit.
2. Hit 'update'
3. Hit 'standard'
6. Hit "M.I.B"
Hi Henk,Ok guys, I got it figured. You will have to be prepared to "hack" your unit with custom firmware to run on your MIB unit. Well, it's not even that, it's firmware running from an SD-card and installing a bootloader into the unit enabling you to run custom scripts on your unit.
2. Hit 'update'
3. Hit 'standard'
6. Hit "M.I.B"
It's likely to be your Mac. Use a Windows machine if you canHas anyone had success in downloading maps using a Mac? I’m having problems and I’m wondering if it’s down to an issue with the Mac.
I should explain that my facelift car has the MHS2 system, so maps are around 12Gb, and are held on 32 Gb SD card, not stored internally. My system has the Congo activator patch, and works very happily with my old 2016 sd card and also with a later 22/23 card from a third party.
I downloaded the latest 2023 MHS2 map zip file from Mibsolution.one and unzipped it using Keka (since I’d read that the Mac unzip tool caused problems). This appeared to work ok. I then transferred the files from the unzipped folder on the Mac into the root directory of an empty sd card formatted as FAT. Again this seemed to go ok, and the file structure looked exactly the same as that on my old Audi card. When I tried it in the car however, after loading about 20% it came up with error “navigation data are invalid”
Any ideas welcome
TIA
Mike
Thanks alpesh26. Nothing I’ve read is categoric about whether it will work with a Mac or not, but I’ll dig out my old windows laptop and go through it all again on that.It's likely to be your Mac. Use a Windows machine if you can
Macs add some hidden files in the folder structure, for most applications it doesn't make any difference, but the Audi system probably wasn't expecting them and didn't like itWell, I went through the whole download/unzip/sd card process today using an old Windows laptop, and to my relief the new MHS2 2023 maps uploaded to my MMI successfully.
So as suggested by @alpesh26 the problem was definitely caused by the Mac. Strange because the files looked exactly the same, so I can only guess that the Mac was adding something hidden which screwed things up.
Anyway, I post this as a warning to anyone else trying to do an update using a Mac.
Thanks Alpesh26. Every day’s a school day!Macs add some hidden files in the folder structure, for most applications it doesn't make any difference, but the Audi system probably wasn't expecting them and didn't like it
The 8V does not support remote functions. Connect is pretty much only live traffic, satellite view and send nav destination.Can anyone tell if my 2019 A3 (MHI2_ER_AU37x_P5089) can activate Audi connect to be able to use the features of open/close door via App and send destination from phone to MMI?
At the moment, Audi Connect displays "the service is unavailable" and "the data connection is restricted". "Activate data connection" is "unavailable" as well.
But the (external) SIM works with Google Map and Online Search, Live Traffic info without problems. (It doesn't come with internal SIM.)
I've tried many times with enabling/disabling Data Connection and rebooting MMI without success.
BTW, I'm in Australia.
No, I don't. is it the reason of "service is unavailable"?Do you have an active Audi connect subscription?
Thanks for letting me know. the "service is unavailable" and "data connection is restricted" messages are driving me crazy. At the moment, myaudi app doesn't show and info about the car (apart from the model and VIN number) and can do nothing. Do you know why and how I can get around it?The 8V does not support remote functions. Connect is pretty much only live traffic, satellite view and send nav destination.
