Car is now MOT'd so no excuses for not cracking on with the DSG swap... other than lack of motivation at the moment!!... the recent rather warm weather and being a little busy work wise has numbed my enthusiasm some what coupled with spending a good couple of months sorting the body work out I feel I just needed a break...
That break will be coming soon as a week off work in which time I might even build up a bit of motivation to make a start... in the mean time... I bought these...
PXL 20220814 154546219
My car never had them fitted as standard (they were an option?) and have been on the fence about getting some... however these came up at the right price and are for the most part in decent nick... they were dirty obvs and had a couple of scratches on the ali covers but generally nice..
PXL 20220814 154556519
PXL 20220817 153136207
Taking them apart was a bit of a pain as one of the screws snapped off in the casting... I will address this at a later date but its not really made it unusable...
PXL 20220817 162636946
PXL 20220817 162644202
Painted the inside...
PXL 20220820 172257583
And cleaned everything else up... used the DA on the ali cover... which I am pretty sure is anodised... this means that it will make removing the scratches a bit more difficult so will ask a few of my engineering friends for advice on sorting this out...
PXL 20220820 172845563
All looks lots better though...
PXL 20220820 180922604
PXL 20220817 153104888
PXL 20220817 153309633
PXL 20220820 181640629
...and as my car is silver they do not look too obvious either...
PXL 20220821 123430668
Pretty happy with that... although I now have the gear to mod for folding mirrors and the bases won't work with the ali covers... would need to get B5 ones I believe to get it working... and tbh I CBA :)
Next little job was to sort out the DSG selector... or more the colour of it... I have only been able to find 'grey' leather ones... the S3 8P is black I believe but they typically run to 3 times the amount of a more basic model so decided to dye the leather instead....
I got the kit from the 'Scratch Doctors' and its pretty comprehensive...
PXL 20220820 160540974
Following the instructions I cleaned off the original coating then applied the black dye...
PXL 20220820 161936473
PXL 20220820 170733663
Finished off using the matt clear coat they supply...
For comparison this is the original grey knob (fnarr) against the now black gaiter it came with....
PXL 20220820 170746879
I also found a perforated leather knob (fnarr) that was grey... now black :)
PXL 20220812 212746508
Put together in the modded trim...
PXL 20220821 125809376
PXL 20220821 125817381
Happy with that :)
With all that out of the way I moved a load of the kit needed for the DSG swap into the boot of the car... hoping that knowing this is there it will get the motivation going to crack on lol
PXL 20220821 150933413
Reactions: S3AMJ, Dohcwp, desertstorm and 2 others
When you bringing the A4 down to Bills mate??
Hopefully within the next week! Done as much as I can but time has come to get this thing out of my garden!
Reactions: S3AMJ
Happy with that :)
I used to hate those mirrors but then when I got them, I started to love them. Dsg conversion looks some work though PT!
This is a goldmine of knowledge here, this thread needs to be archived on archive.org :thumbs up:
Reactions: <tuffty/>
Stop fannying around with mirrors and leather Tuffin and get that gearbox in! (With love)
Planning on making some progress next week Mr Wellings... these things need a considered approach rather than a pour flammable liquid into a relentless manifold and see what happens kinda thing :)
Made a start :)
PXL 20220827 132102615
PXL 20220827 132127375
Had to drop the exhaust and the front of the prop to get the heat shielding off the get at the selector...
PXL 20220827 143654841
PXL 20220827 143701729
Now that the shafts were out I could see how they compare to the Mk1 TT 3.2 DSG shafts I have...
PXL 20220827 132048491
PXL 20220827 132053662
Left shaft is more or less the same length which tbh I was expecting based on my previous measurements... I could in fact replace the left drive cup with an 02M cup and use the S3 shaft but tbh I would only want to do that if I could run the right side on a normal inner CV but the R32 transfer box I have uses the wrong drive cup and as its part of the shaft that goes through the transfer box its not just a case of swapping it out...
The right shaft is clearly shorter than the S3 one which again is to be expected as the 02E (and 02Q for that matter) transfer boxes are 'wider'..
I have the TT's transfer box but cannot use that as the transfer boxe's shaft is too short for the R32 box... I also have a transfer box from another quattro (not sure which as was sold as spares/repairs) and this has the right cup for a normal CV but the shaft is too long!!... seems very un VAG like to have that many variations of the same thing but I will do a bit more research at some point as I would prefer to use normal inners over the trilobe type...
On that subject... I spent today stripping and cleaning the shafts (fnarr)... the boots were questionable so I really wanted to replace those before fitting them...
PXL 20220828 130926902
PXL 20220828 130932396
The outers looked fine but had to replace the boot on the right shaft so cleaner the outer joint too
PXL 20220828 162019462
The inners on the TT DSG shafts are trilobe... not a massive fan of these but it seems VAG have taken to use these on more and more cars these days so hopefully they will be ok for a while given the power I am running... I do plan to look into converting back to normal inners as mentioned before though...
As the R32 transfer box inner is a different pitch to the TT one I had to buy a new inner so it would fit... the design is a bit different though.. (not a genuine joint) but uses needle bearings and not spherical bearing style setup like the OE... not sure if there is any real advantage to this tbh as trilobes are generally weaker (but cheaper to make no doubt)...
PXL 20220828 162043305
PXL 20220828 162115101
PXL 20220828 162126221
Left is the pattern part which is the same PCD as the middle OE one from the left shaft... the joint on the right is the right shaft inner... fits perfectly on the TT transfer box but not the R32 one!!!.. :)
PXL 20220828 162211975
Motivation is coming back now... will be doing a bit more tomorrow and then on Tuesday I hope to get back up to Bills and sort out what I need to do on the gearbox to get it ready for fitting...
Reactions: S3AMJ and hydro s3
Nice work mate! Good to see it’s moving along looking forward to seeing it once it’s finished
Tri Lobes cant handle alot of power, my one mate keeps blowing inner cv's and thats on an a3 thats probably making between 300 - 350 bhp
Made a start :)
Yeah... fully aware of the limitations but hoping that it being AWD will help lessen the strain until I sort out a more suitable solution
Gearbox stuff done today.... the mechatronic cover was pretty rusty so I bought a new one to replace it with...
PXL 20220829 102118393
PXL 20220829 103049831
Bottom two bolts were particularly difficult and shock (actual) horror!...
PXL 20220829 103058871
...one sheared... yay!.... (said no one ever!)
Probably should have cleaned the box first too as all kinds of nasty was falling in places I'd rather it didn't...
PXL 20220829 103116438
PXL 20220829 103120413
Bit of vacuuming and careful cleanage later and I was ready to tackle the sheared bolt... first job... flatten it enough to get the punch on it...
PXL 20220829 105855040
Drill a hole then insert extractor... apply heat (carefully)... and bingo bango bongo!!!
PXL 20220829 112141158
PXL 20220829 112327509
Phew!!!... I then chased the threads to be sure all was good...
PXL 20220829 112617249
Next up was to drain the oil (what was left at least).... DSG boxes are a bit different to normal boxes when it comes to sorting the oil... manuals are typically filled for life but DSG require "regular" (if you think 40k is regular) oil and filter changes due to the wet clutch setup (much like the haldex)...
Undoing the oil drain plug reveals a plastic (and fragile) filler nozzle used to 'set' the final fill depth... you unscrew this to drop the oil then screw it back in and fill from underneath (again, like the haldex)...
PXL 20220829 115436021
...there is also a process of warming the box up and going through gears etc to do but obviously I am not in a position to do that at the moment and do not want to start the engine once fitted with a dry box (fnarr)... so I plan to put about 5ltrs in to start with and then once I have tested the box is ok go through the process to top it back up...
There are a few ways people say it can be done to ensure the right level... one is the measure the oil volume that came out and replace like with like but there was certainly no more than a litre or so that came out (assumedly drained before being shipped to me) I have no real way of telling how much is actually left in there so will have to make an educated guess then sort it out once running...
Before fitting the new cover I had a go at cleaning up the mounting face as there were signs of corrosion and crustiness so wanted to make the new seal would 'seal'
PXL 20220829 115731016
Bit of scotch bright and brake cleaner later and the face was looking better...
PXL 20220829 120017900
The old cover's seal did not look healthy at all
PXL 20220829 120037205
and neither did the old cover...
PXL 20220829 120816476
Still... new one looks fine...
PXL 20220829 120759684
I think I might add some wax protection around it too as I have seen a few of these now and they all end up looking a bit nasty after a time...
Last job of today was to sort the left drive cup out... I swapped the R32 one over to the Mk1 TT DSG one as it sits closer to the box giving the right distance for the left shaft...
PXL 20220829 121642260
And on the subject of drive cups... I grabbed my mate Alex's transfer box he is using for the DSG/AWD conversion on his Mk4 Ibiza... this one came from a Mk6 Golf R...
PXL 20220829 122742378
It fitted up perfectly which is a good sign at least and has the right cup for a proper inner CV...
PXL 20220829 122819333
The left drive cup from an 02M box (like any S3 manual) will fit onto the box too apparently (not tried this as yet) so if I can get hold of one of these transfer boxes I can use the proper inner joints... one for the watch list given they seem to carry "R" (same as BAM or RS) tax :)
Plan to try and get the car ready to accept the box tomorrow... strip stuff from the bay to be able to access the gearbox for the swap and remove things like the clutch pedal and swap out the brake pedal too... maybe even get the selector swapped over!!!... makes it kinda real then lol
Day at home doing things....
I painted the transmission cooler as it was looking a bit scabby...
PXL 20220830 093541878
Then moved onto the car... first job was to swap out the old fuse box for the inline pump and WMI for a new 4 fuse setup to allow me to fuse the DSG selector power... the fuses have LED's that light up when blown as its difficult to see where I have it fitted and had the fuel pump fuse blow on me a month or so back and only noticed as I didn't hear it running
PXL 20220830 100132485
Redid all the crimps too....
PXL 20220830 111002924
Now for the 'fun' part (said nobody ever!)... to remove the clutch pedal I needed to get to the master cylinder behind the heat shielding, where there was a turbo and a downpipe in the way... so removed them :)
PXL 20220830 121724633
PXL 20220830 124223017
Much better access... the pipe has a spring clip holding it and you need to block off the fluid feed from the brake reservoir so used an M8 shouldered bolt cut down to size for that...
PXL 20220830 132124497
Inside you need to undo three 13mm nuts and unplug the clutch switch then the whole clutch pedal assembly just pulls out... watch out for fluid as this will drip everywhere...
PXL 20220830 132635826
This of course leaves a nice pear shaped hole... I will need to make up a cover plate for that later
PXL 20220830 133309473
You can remove the brake pedal without having to remove the brake pedal assembly... however you do have to smash the plastic retainer apart to be able to do it...
PXL 20220830 135339734
My TT pedal didn't have one so I had bought a new one anyway...
PXL 20220830 135352167
...but I ended up taking it back out to fit on the servo actuator rod first then fit the pedal and clip the plastic clip into the pedal after...
PXL 20220830 140734018
That's the pedals done...
PXL 20220830 172914432
Next job was the selector... old manual one came out pretty easy but the 6R Polo selector I am using required a bit of modding to fit (go figure)...
A couple of extra holes at the back were needed...
PXL 20220830 154704134
I had to mod the back of the selector to fit under a bracket that the S3 has for some reason...
PXL 20220830 155841099
And cut the rear studs short as they hit the inside of the centre console...
PXL 20220830 154943043
...which needed a little modding to get the nuts on...
PXL 20220830 161841475
But after all that... the selector was in...
PXL 20220830 161845180
Sadly it seems that the lever sits higher than it would in an 8P (or 6R Polo I would assume) as the 8P DSG gaiter I used wasn't big enough (depth) and would stretch and pull out of the trim panel when the lever was moved to extremes...
PXL 20220830 162528114
PXL 20220830 162549038
However it was fine in neutral so left it there for now :D
PXL 20220830 162644591
Other than the gaiter issue which tbh I wouldn't have known about until I had fitted it I think the selector mods turned out quite well...
PXL 20220830 165401430
Bit more work in the engine bay to do to prep for the gearbox swap now....
PXL 20220830 165121742
Need to remove the transfer box and power steering pipes (I have a DSG one to go on as they are differently routed), remove the starter motor and anything else attached to the box then I can look to bring the DSG box home from Bills and I guess just get on with it :)
Reactions: S3AMJ, hydro s3, Ian W and 1 other person
May have a solution for the short s-tronic gaiter... fitted a spare 8L one I had kicking about and this seems to work perfectly in park and S mode positions... its a bit tatty but I have another one on the way so will look to remod the mod to get that ticked off... part of me actually likes that the lever looks like a manual with no auto display but then I also kinda like that its there for the double take :)
PXL 20220831 130846177
Went to Bills to sort out the box... fitted a new filter and pumped 6ltrs of oil in which in hindsight was not really the best idea (more on that in a bit)... the box was pretty much empty and should take 7ltrs from dry... I added 2ltrs at a time and used a DSG flywheel to spin the input shaft as it drives the oil pump to circulate oil round... the oil cooler is thermostatically controlled and there wasn't any oil coming up through the ports to the cooler but 6ltrs is enough to get it all running and I can sort out the rest later...
PXL 20220831 155136875
PXL 20220831 151137752
The transfer box has its own oil supply and takes GL5 75W80... this is different to the oil in the DSG of course and is why the newer transfer boxes no longer share oil from the box like the 02M boxes do... however... I neglected to realise that removing the transfer box (as I was going to do to fit the box) was no different to pulling a drive cup that would essentially let the box oil leak out... epic fail!!!... so I guess I will be fitting the box with the transfer box on then... hopefully!!!
While at Bills I also checked if I could use normal inner cv's on my TT drive shafts...
PXL 20220831 144518953
PXL 20220831 144535639
That would be a no then!!... guess I will be doing the drive shaft shuffle at some point when I finally need a right shift lol
After that I went home and pulled the transfer box and PAS pipes off (DSG uses a different line from the pump to the rack)... undone all but three of the bolts holding the box on...
PXL 20220831 183139686
Today I dropped the manual box...
PXL 20220901 085522907
...pulled the old spigot bearing (the engine used to be attached to a DSG, you don't need a spigot bearing for a manual) and fitted the new one supplied with the flywheel...
PXL 20220901 091634623
PXL 20220901 092603012
PXL 20220901 093207015
PXL 20220901 094351375
Popped back up to Bills and flung the DSG into the back of the A2...
PXL 20220901 125527909
Lifting it back out the A2 at home was well... hard!... its soooooo heavy!!... I can lift 02M's all day long but the 02E is another league!
PXL 20220901 134334613
One thing to bare in mind too is that the R32 gearbox mount is lower than the Mk1 TT 3.2 DSG mount...
PXL 20220901 141229201
...so will use the TT one as thats designed for the Mk4 platform... part numbers for ref...
R32 one that came on the JPZ gearbox...
PXL 20220901 141300641
Mk1 TT DSG mount...
PXL 20220901 141306482
After much grunting and swearing I had dragged the box under the car ready to 'plonk' onto a jack... and then it rained!!!...
PXL 20220901 152106142
Much dampness and sad face followed as I rushed about clearing up my tools and wiping them down before putting them away... whilst getting wetter...
So close!!!... maybe tomorrow... or whenever the weather stops being a hole of the rear...
Reactions: S3AMJ, hydro s3, Ian W and 2 others
Epic work as usual.
If you're planning on manhandling that DSG box in on your own off a trolley jack then you deserve a medal :tearsofjoy:
Epic work as usual.
I have a mate helping thankfully... lifting it out of the back of the A2 and dragging it under the car was enough... 75kg or so apparently
  • Wow
Reactions: Ian W
I Love those A2's pity they're so rare and expensive here, Alot of the Guys here seem to hate it for some reason.
Its a marmite car for sure but has been the most practical and reliable car I have owned tbh... ticks all the boxes as the ideal second car
Weather looked iffy this morning but had cleared up by lunchtime so out I went....
Ended up having a go at fitting the box myself as my mate couldn't get to me until after 6pm and wasn't sure what the weather would be like... figured if it got to a point I felt it needed an extra person then I would wait... If I got it in then winna..
Getting the box onto the jack and centred enough to balance was the challenge... that way at least the jack would be doing the heavy lifting and I can use less effort to keep it balanced and more making sure it was heading in the right direction...
PXL 20220902 132417519
Just in case you are wondering... the angle the jack is over at is within factory tolerances for DSG box installation... probably!!! :)
I used the lever bar to help move the front of the jack over while positioning the box... and...
PXL 20220902 135513419
PXL 20220902 135502085
PXL 20220902 135532571
..in!!!... phew!... wasn't that hard really in the end... yes... the box is chuffing heavy but work smarter not harder right?
I need to now drain the coolant to sort the oil cooler out plus tbh I want to remove a load of the pipes to be able to make sure the starter is fitted correctly and to route the DSG PAS pipework as there doesn't seem to be any room to do this...
PXL 20220902 163049910
PXL 20220902 163055504
The oil cooler hoses will be easy...
PXL 20220902 140229213
The hose in the top of this t-piece goes to the right of the cooler and I just need to get a 'U' shaped hose to go from the 'T' to the left of the cooler...
I also need to wire in the starter inhibiter and the reverse light as well as redo the selector gaiter...
I will be painting the subframe and shafts hopefully next week if the weather keeps off with the aim to get all that back together soon after...
I have also noticed a small weep from the oil drain so thats coming off to be tested and fixed if need be and I have seen a crack in the exhaust manifold... no white staining that suggests its leaking but will get it welded while the car is mostly apart... bit of a shame that the mani has cracked so soon but not unsurprising given its a 70 quid aliexpress special..
Happy with the progress though... the week off work has been productive...
Reactions: S3AMJ and Ian W
decided it would be a good idea to drain the coolant and remove the rad to get better access to the area by the top and front of the box...
PXL 20220903 113708908
Somewhat of a surprise was how much coolant came out... I collected it all as its less than a year old (changed when I fitted the CFS rad) and wasn't grotty looking...
PXL 20220903 125126632
...yep!... 8 ltrs!!! and I think there is still a bit left in there...
I needed to do something with the coolant anyway to sort the gearbox cooler out but removing the rad has made working on the car a lot easier... (if I ever have to do this again the engine is coming out!!)
PXL 20220903 121505492
Not sure how I would have got to the lower starter bolt tbh if I hadn't....
Access to sorting the PAS pipe was a bazillion times better too... once the starter was in it become obvious (ish) where it needed to route...
PXL 20220903 130524723
PXL 20220903 130516281
I had to give some attention to the turbo oil feed pipe too as this was now quite close to... well, everything!...
PXL 20220903 155812439
Attached one of the box cooler hoses, just waiting on a 180 degree hose to sort out the other side and thats the coolant stuff sorted...
PXL 20220903 155757753
I wired in the reverse light to the relay panel and ran the starter solenoid wire up to its relay too... just got to grab some 2.5mm wire to run from the relay back to the starter solenoid and thats the inhibit circuit sorted...
By this time I was done... for the week!... productive week off work... although a little bit of R&R would have been nice I did what I set out to achieve and behold!... the box is in :)
With the weather being a bit on the iffy side over the coming week or so I am not sure how much I will get done but two jobs I need to sort before I can get the car running again...
Spotted a weep of oil from the oil drain so will be dropping the oil and removing that for a smoke test...
PXL 20220831 175406201
The other more disappointing issue is this...
InkedPXL 20220830 132040413 edit
...a crack... a little surprised at this tbh as the casting is quite thick and my EGT's are pretty low typically maxing out at 750 degrees measured just past the collector in the hotside... not exactly hot in the grand scheme...
Been making a little progress on the selector mods too but will post about that when done...
Reactions: S3AMJ
Mega work PT! Shame about the crack in the exhaust manifold. Looks like taking the front off the car made a big difference in access……. Something to consider for myself.
Great work, so much more than I did. I never bothered swapping the brake pedal just removed the existing clutch pedal and actually left the slave cylinder in place so that I didn't have to block up a hole, It weighs next to nothing. I didn't bother with the starter interlock, I always put the car in park when parking it so not an issue for me. Are you going to use the in line thermostat on the oil cooler for the transmission?.
I am aware of the stat but I am keeping it as god intended for now... will be running the map at actuator pressure initially until I know it is all working ok and ideally need to get the box mapped before I turn it up as with its current iteration I suspect my mid range torque is a bit higher than before as I am running 1.2bar a lot sooner in the rev range now and was at nearly 480ftlbs before
As my car is primarily used to get me to places in a 20 mile radius I am not entirely sure I need it as yet but want to get a feel for what temps are doing what first as I think I need an engine oil cooler anyway so will just evaluate the whole cooling situation once I have some data...
I am not using the second rad yet as I think there is cooling capacity in the CFS rad for now but again will look at the data once I have some and go from there...
You will find that the engine takes a little longer to warm up without the stat. I fitted an alloy filter housing that I have fitted a temp sensor too and log that in Ignitron. I find normal driving DSG oil temps take a while to get to around 60 degrees, when pushing on they might get to 80 degrees. Flat out on track they peak around 110-115 degrees. So most of the time there is no coolant flow through the oil cooler.The oil temps I see very closely match those seen in VCDS of the gearbox oil temp.The stat is around 80 degrees I think and I have seen several posts by people with DSG cars that take a long time to warm up and have found the DSG stat has stuck open.
I use a Golf R DSG cooler rad and pass the coolant from the engine through this then into the oil cooler on the gearbox. So I have better cooling on the DSG by using cooler than engine temp coolant. This is how they do it in the Golf R , TTS, S3 etc.
Getting warm is something a VR6 has no issue with lol...
Thanks for the info... I have the take off ports for the second rad if I need to and the VR coolant paths suggest the DSG cooler gets fed directly from the cool side of the rad
VR6 Cooling
Reactions: desertstorm
Having a chill day today as my 'holiday' is now over and its back to work tomorrow!! booooo!
Got hold of a length of 3.0mm wire to finish the starter inhibit and a 'U' tube (not like the thing @Prawn is the queen of) to finish the coolant system off with...
PXL 20220904 135853080
PXL 20220904 135859811
I can start to put the front back together now but will drop the engine oil and remove the manifold and oil drain first...
Also over the past couple of evenings I have been sorting the gear gaiter out... I obtained a spare manual gaiter and re-dyed it black...
PXL 20220902 223219202
Went to try it out and hit another issue...
PXL 20220904 162342816
PXL 20220904 162351518
Seems the indicator panel needed tweaking to allow the trim to fit so had it... and....
PXL 20220904 165113389
PXL 20220904 165422613
W00t!... now articulates from Park to Sport without pulling the gaiter out :)
Happy days... hopefully the weather stays decent enough to let me crack on with some more this week after work
Reactions: MPH, Ian W and S3AMJ
Lovely job on the gear selector! I do really like how you’ve used the black panel, looks very subtle and OEM++ as always may have to ask for your expertise again soon
suprised you didnt change the selector led's e.g green for drive and yellow for sport etc
Things have slowed a bit what with being back at work and the weather but have managed to get a few jobs done...
First up was to drain the oil and remove the exhaust mani and oil drain...
PXL 20220906 180550941
....done... took it up to Bill's and aqua blasted the mani...
PXL 20220907 111818083
PXL 20220907 111825539
Sad face :(
Alex tried to weld it but...
301736009 5787029814648808 9141131039800520592 n
He has a plan... will see what happens... worst case is I buy another and sort that one out in the hope that they used actual metal this time around... its a shame as the mani is actually rather decent as a 'thing'... needed a bit of modding to suite but it works... apart from the cracking of course... plan 'Z' will be to fabricate a tubular mani but tbh I am happy if I can get one of these just to work...
While that saga continues on I got around to refurbing (painting obvs) some things...
The front drive shafts...
PXL 20220907 164627053
PXL 20220911 133934229
The subframe... wire wheels and Hydrate 80 to sort the rust
PXL 20220910 130358063
Etch primer....
PXL 20220910 145906865
Zinc rich primer...
PXL 20220910 152249336
PXL 20220910 154014919
...and finally Tough Liner as the top coat...
PXL 20220911 114626715
PXL 20220911 125408714
...and the front ARB (R32 one)
Along with the front arms I did a while back they all look loads better and should be a little more resilient to the elements...
PXL 20220911 164600470
Manifold and maybe the oil drain are essentially holding me up at the moment so will have to see what happens with those... hopefully not too long now...
Reactions: MPH, craigt1985 and S3AMJ
I have ordered a replacement exhaust manifold... yes.. its another Aliexpress special but I am kinda hoping that this one may actually be made of metal this time... I like the manifold, it works (when its not cracking) so will give another one a go and see where we end up...
I am still getting the current one welded... this will be used to get the car back on the road and the DSG tested etc... I will pull the mani off over the winter and sort it then...
Other jobs that got done...
PXL 20220912 174904475
PXL 20220913 131255186
PXL 20220913 171039786
Drive shafts made up, brackets de-rusted and painted... next up... I needed to mod the DSG selector cable bracket... the Polo 6R uses a different DSG box to my DQ250... the hole for the cable end needs to be smaller and the bracket need to sit back a bit so... measured and marked it up...
PXL 20220913 170626624
Found something suitable to weld into the current hole to make it the right size for the 6R cable...
PXL 20220913 170644036
PXL 20220914 152942830
Threw some metal at it using the hot spanners...
PXL 20220914 163817101
PXL 20220914 163928302
...and test fitted it...
PXL 20220914 170059174
PXL 20220914 170114151
As the MIG was out I made up a DSG oil fill adaptor that I can use with a cheap 3ltr pressure bleeder..
PXL 20220914 151004982
PXL 20220914 171445771
The collection of painted parts is getting larger :)
PXL 20220915 205049852
...and I can't really fit them until the oil drain and manifold is in as it will give me better access...
Reactions: Ian W
Few more jobs done today... refitted the tunnel heat shielding and the front end of the prop... also fitted the left drive shaft as this wont get in my way for anything...
PXL 20220917 152614324
Made up a panel out of 3mm ali to block the hole where the clutch master cylinder passed through...
PXL 20220917 142451060
PXL 20220917 142515893
Fitted brackets for the DSG selector and transfer box...
PXL 20220917 152712274
PXL 20220917 152720478
Fitted the engine bay heat shielding and connected up the PAS pipes...
PXL 20220917 152738121
Built up the front subframe...
PXL 20220917 155749490
...and painted some more things...
PXL 20220917 171633087
PXL 20220917 174146655
The list is getting smaller but still waiting on the mani and oil drain at the moment so I don't want to fit the subframe just yet as it will make it easier to sort out...
Not that its massively difficult tbh but why make life hard :)
Reactions: S3AMJ, hydro s3 and vanilla_ice
The replacement manifold turned up this week... pretty quick considering...
PXL 20220921 164004846
Next job then was to carefully remove the adaptor flanges from the old mani so I (and by that I mean Alex) can weld them onto the new one...
PXL 20220921 160530134
PXL 20220921 160540307
...that went as expected :)
Bit of clean up required then....
PXL 20220921 161514549
PXL 20220921 162032654
....and bingo...
PXL 20220921 170557676
After Alex TIG welded them I needed to do a bit of porting...
PXL 20220923 152021162
PXL 20220923 152026184
Waved the die grinder at it...
PXL 20220923 155624492
PXL 20220923 155614778
Happy days... so I fitted it :)
PXL 20220923 173615242
PXL 20220923 181254994
Nearly looks ready to run... but it isn't... as I am still waiting on a replacement flexi sadly... maybe next week...
In other news... I painted the front headlight levelling assembly :)
PXL 20220920 165852835
PXL 20220922 122251338
Reactions: S3AMJ, craigt1985, mk1chopper and 3 others
As I am still unsure when a replacement flexi will arrive (they are typically made to order) I have decided to try a more available solution... I have ordered up some AN10 fittings.. 2 x stainless weld on bungs, a length of PTFE stainless braided hose and suitable fittings... PTFE hose should be fine for this application as its not got to wind past a hot manifold like a tubular 1.8t one and if it does get damaged I can replace the hose more easily or I will have the flexi to fall back to when it eventually turns up...
This is all due to arrive by the end of the week so I am really hoping to get it sorted this weekend and potentially have the car on the ground next week at the latest...
In the mean time I got onto a job I have been meaning to do for quite some time.... I modded a mirror a while back from a hyundai tucson... basically the same auto dimming mirror found in the newer Audi's but has a green compass display rather than a red one...
PXL 20220925 150430786
To get to the display I needed to split the mirror... used blue masking tape to prevent marking the plastic...
PXL 20220925 151654779
Carefully removed the "mirror" to get to the display which basically has a green filter over it...
PXL 20220925 152205203
PXL 20220925 144952768
Its held on by a couple of sticky strips so can be removed carefully..
PXL 20220925 145004424
I used some red lighting gel I have kicking about for my photography to change the colour...
PXL 20220925 152440625
PXL 20220925 145148813
Its a little darker than the green it seems but tbh thats not really an issue for me... if you try this it may be worth trying a few 'shades' to see how you get on...
All reassembled and looks OE now...
PXL 20220925 154709707
This time I actually wired it up as I had fitted the mirror a while back and never got around to it... I also wired in a 'dash cam' fitted behind the mirror while I was at it...
One last thing... I bought a spare DSG box....
S l1600
...mainly because VR boxes are a bit thin on the ground, I feel a little happier having a spare of something that is known to be a little temperamental and it was actually very cheap... the other 'upside' is it has the right transfer box drive cup for ball and cage inner joints...
Guess that means I will be selling the manual box after all
Reactions: desertstorm, S3AMJ and s3mad_dude
Thought you finished the mirror mod loooong ago already
D
721
Deleted member 65282
D
