Drive Belt - Power Steering Noise
P
purple8
Guest
Morning all.
I have had a noise coming from drive belt area on and off for a while, shushing noise, suspect idler.
But now on full lock unless I rev the power steering makes an awful noise on full lock.
I am hoping its just going to be the belt and not the pump? any tests I can do in situ . If it is the belt is worth doing the tensioner and idler at the same time.
I had same issue two years ago and it turned out to be the PAS pump. Had it replaced under warranty. Check fluid isn't low first.
Azeem
yeah checked the fluid as that was low the other month and made a similar noise.
9
4K
750
14
732
