RS3 8Y General Discussion Thread.
360 cam and Tyre pressure monitoring not available on Vorsprung ... but Audi none spinning wheel caps are for an extra cost PMSL :tearsofjoy:
How do you tell the difference which ones have Tyre pressure monitoring and not? Can you not get it added on after even thought I’d be a pain
It appears that the few 'launch editions' which came to the UK were fitted with TPM but this is NOT a feature available on any of the other cars including Vorsprung.
It may be possible to retrofit but not sure.
(the tell tale sign is the silver valve caps on cars with TPM)
Reactions: ZB1 and Daggerit
And the Frankenstein cars too… Weird the base models with some options get it but the top of the range Vorsprungs don’t. Yet another Audi **** up.
Reactions: 8YARWY
So cars with all black stems are normal valves ? You can tell a TPMS valve stem as it’s ‘chunkier’ in dia and on most cars it’s grey.
Reactions: RS03??? and Snake Pliskin
Can’t be done without Unlocking the module with Geko access.
8V didn’t need this, Audi have made module access a lot tighter on the 8Y.
Can’t be done by inputting a code on vcds? What about Odis?
Hi
You can unlock the A3 8Y SFD free using obdeleven pro edition which will give you 90 minutes before being locked and if you need more time you can just unlock for another 90 minutes etc. You can also after unlocking, you can remove the obdeleven and replace with VCDS and you would have the remaining unused minutes left.
Hi
Do you know anyone that’s done the 8Y Active TPMS retrofit using the SFD via OBD11 ?
My vorsprung is waiting to be loaded onto the ship
On the dealers system my vin number is showing as having the 360 camera fitted.
Has it definitely been removed from the vorsprungs?
Reactions: Stu-27, RS03??? and garethdj
I was told it was and that the price had been reduced. Read like a generic email rather than one specific to my order
Wonder, if the 360 wiring was installed and then being supplied without the chip bits not installed due to shortage.
Can you send me.Vin i try to to.check
Can’t remember which topic it was in but someone mention the wrinkles on the seats. Just watched Joe Achilles video of his 9 month old M3 with the optional carbon buckets and the leather has actually worn and burst through.
If you’ve not seen what they do to cars, you need to take a look.
They’re very active on insta, they’ll have it looking better than new.
A couple of miles up the Road from me, Tend to specialise in modded cars. They retail some nice stuff but at the very top end of the price spectrum.......
Not sure that’s correct. I have done my car,HGV, bike test and always had to signal right/left when overtaking, whether on single/dual carriageway.
Rule 133​
If you need to change lane, first use your mirrors and if necessary take a quick sideways glance to make sure you will not force another road user to change course or speed. When it is safe to do so, signal to indicate your intentions to other road users and when clear, move over.
Its not specific to left or right hand manoeuvres.
Wish the **** who knocked me off my Bike as I was overtaking him & another car in front realised that.....
  • Wow
Reactions: Jcbmally
Hope your alright fella but yup seen that a few times where I work.
Reactions: pburv
Hey guys, steering wheel question. Whilst i know that the RS3 8Y MFSW buttons are different to the 8V in the fact that there is an RS button on the R/H MFSW button cluster, is the plastic steering wheel bezel the same on 8Y & 8V? I ask as I received my custom steering wheel today and want to install a bezel on that rather than remove the OEM bezel from the steering wheel that comes with the new RS. Any help appreciated :thumbs up:
I believe they are the same bezel but not 100% without having mine in front of me. The S3 8V steering wheel was certainly the same as the 8Y one other than the RS having the button as you mentioned.
Hi all, I’ve just seen a YouTube video from Stoke Audi with a black Vorsprung used for sale at £75k if there are any taker??
Reactions: Jcbmally
Cheers bud. Thats my thoughts exactly. Right off to ebay to search for a bezel!!!!!!
Apologies, the photo of my 8v one is poor but here there are together. Look identical to me.
Screenshot 20220203 134014 Photos
Screenshot 20220203 134029 Gallery
Cheers fella - I just need to find the part number or a used one on eBay but not having much luck!!!
Am I right in thinking you are looking for a complete steering wheel or just certain parts??
Either way does this interest you?
:thumbs up:
Reactions: Jcbmally
:thumbs up:
Thanks my man. I just need the steering wheel Bezel - @Mastachaz is looking up part numbers for me, but appreciate the post from you :respekt:
Reactions: pburv
Where does the information about no TPMS come from? As that is headline shown on the RS monitor.
258K
197
39K
17
9K
